The differences between Peco and Hornby standard Settrack points are more obvious and the Hornby point connecting the engine shed has been causing issues with departing trains. This is a real problem with some Mainline locos as well as the Triang DMU with its modern Hornby wheels.
The Re-railing Team got fed up with being called out every few days and the Operations Department found it increasingly difficult to work out which locos would safely negotiate the points. Due to the location of the point some electrical work was required and to reduce ground works cables were connected directly to the point before installation.
Installation is expected to take place shortly and there will hopefully be no more complaints about spilt beverages from passengers
