Edgware GN,
Ex-Pat
Re: Edgware GN,
Postby Ex-Pat » Sat Nov 16, 2019 12:06 am
Another amazing "test-tube" loco - I know it can be dangerous to weather valve gear, but some oily steel (or whatever's on the coupling rods) paint on the connecting rod and valve gear would really be the icing on the cake?
manna
Re: Edgware GN,
Postby manna » Sat Nov 16, 2019 5:37 am
G'day Gents
Oh, this will get weathered, the only pictures of them that I have seen them clean, were at the 1925 Centenary at Shildon. The rest of the time, they were filthy.
manna
manna
Re: Edgware GN,
Postby manna » Sat Nov 30, 2019 6:02 am
G'day Gents
Changed track again, thought I'd like to see my Heljan O2 in LNER colours, so out came the paint pots and transfers, couple of days later, when all dry.
Also having a old Kitmaster Stirling single tender knocking around, I decided to knock up a running chassis for it, so it'll be ready, when I build another J4 for it.
A reasonable sized Grass fire came within half a mile of our home over the weekend. Burnt out a couple of hundred acres. No damage.
then on Monday a Brown snake about 3 foot long came into the backyard, to play ? with the dogs, it escaped by going under the house, it tried to get away again later in the day, but the dogs chased it back under the house, Haven't seen it for a couple of days. Hope it's gone walkabout.
manna
Ex-Pat
Re: Edgware GN,
Postby Ex-Pat » Sat Nov 30, 2019 5:15 pm
The loco shed has caught my eye - you've kept it fairly well hidden - had to go back to page 15 for a previous snatch of it.
Any chance of less obscured close-up photos & details please?
manna
Re: Edgware GN,
Postby manna » Sun Dec 01, 2019 7:20 am
G'Day Gents
You wish is my command, Ex-Pat. :lol:
It is a pair of old Airfix kits, glued together, I've had one of them since 1971, the other is even older, maybe 1967/8. I do need to finish it off, I still have all the bit's to do so, but Edgware lost it's engine shed back in something like 1888, when it fell down during a Blizzard, so do I finish it and add an imaginary loco shed, ??? Then again, the line to London Coney is imaginary too. :mrgreen:
manna
PS A couple of pics of our Grass fire.
Ex-Pat
Re: Edgware GN,
Postby Ex-Pat » Sun Dec 01, 2019 10:56 am
Thanks manna.
It really does the job for me, and just oozes the age and decrepitness that one would expect of a secondary/minor route.
Was the bottom photo's two-tone black the forerunner of BR's two-tone green I wonder?!
Will your grass fire photo inspire anybody to model crop-burning - a feature I cannot recall ever having seen being modelled?
manna
Re: Edgware GN,
Postby manna » Sun Dec 01, 2019 7:18 pm
G'day Gents.
The two tone black gives it's age away, grey 1967/8, almost black 1971.
Good thinking about the burnt crops/embankment, I'm slowly 'Greening' up the layout, and a bit is waiting for me to get round to doing it, so a burnt bit of embankment, might look different.
I have seen bits of burnt embankment on a couple of layouts over the years, but not many.
manna
manna
Re: Edgware GN,
Postby manna » Tue Dec 10, 2019 7:57 am
G'day Gents
After a bit of thought (hard as it maybe), I've added an extra siding to the loco shed, the logic behind this is Edgware is a Junction, so would probably have a small engine shed. I'll have to see if it grows on me !!
manna
manna
Re: Edgware GN,
Postby manna » Sun Feb 02, 2020 5:12 am
G'Day Gents
Things are improving, time wise, been banished from the house, I'm creating to much 'Dust', I'm creating trains, 'Dust' is a by product :lol: So I'm back out in the shed, so less work on 'Hot' days, and we've had a few.
The P1, is now a runner, had to move the cylinders yet again, but it did the trick, no photo, as it still looks the same.
I've been having a go at a couple of Hornby 0-4-0's, rewheeled them so I can fit them under my C12's, two bodies and one chassis, which doesn't work very well.
I bumped into my G1 0-4-4T again, terrible runner, so I pulled it apart, cleaned it and put it back together again and it worked with a bit of extra weight, no idea what was wrong with it, have fitted the rear bogie, going to need more fiddling, but it has a new chimney that I've turned in an electric drill.
manna
Ex-Pat
Re: Edgware GN,
Postby Ex-Pat » Sun Feb 02, 2020 8:46 pm
Looking forward to photo and details of the G1 chimney (is it brass, or what?).
manna
Re: Edgware GN,
Postby manna » Mon Feb 03, 2020 11:51 am
G'Day Gents
Sorry about that, I was going to follow up the last post straight away............but. :oops:
Anyway.......The chimneys are made out of Perspex, ( A Venetian blind winder) , cut off 6 inches, stick it in the end of your Electric drill, which you've already locked into you vice, then gently use a small 1/4 inch chisel, to make the shape of the chimney, then clean up with small files, it won't take long to get the hang of it.
manna
Ex-Pat
Re: Edgware GN,
Postby Ex-Pat » Mon Feb 03, 2020 6:29 pm
Thanks manna -as inventive as ever (and saves a few bob as well!).
manna
Re: Edgware GN,
Postby manna » Sun Feb 16, 2020 8:53 pm
G'Day Gents
I have restarted work on 4419, which I started working on more than 40 years ago, this time I might get to finish it, Fiddled with it today, changed the motor, gave it a clean and away it went, so just the valve gear to fit. Whilst looking for more information on 4419, I came across 3279, and found out that she had 2 guise's, (possibly 3) and ran for many years as a 4 cylinder simple engine, the look of it interested me, so with a little more research,I found out she was quite different from her sisters, outside cylinders, wider running plate and a wider cab, and big blocky cylinders that came part way up the smokebox :shock: So an Great British Trains, Flying Scotsman, was sacrificed, well the running plate, the rest will be scratchbuilt, a old tender drive A3 chassis has also been butchered.
The valve gear on the Robinson B1 is finally working. Most of the other engines are on hold waiting for parts, which should be here soon, along with a few other goodies.
manna
manna
Re: Edgware GN,
Postby manna » Wed Feb 19, 2020 4:19 am
G'Day Gents
Trying to clear some space on my already overcrowded workbench, I decided to concentrate on the G1, as it need the least amount of work & spare parts, most of the others need 'Bits' which I'm still waiting for. There are still things that need doing, glass for the windows, sandboxes, weathering and couplings (I've stuck a three link on the front) Not to bad a loco, for one that used to be a damaged Hornby N2.
manna
glencairn
Re: Edgware GN,
Postby glencairn » Wed Feb 19, 2020 9:38 am
'Steam in the Suburbs'. Loving the thread. Thanks for posting.
