East Cheltwell
Eastern
Re: East Cheltwell
Postby Eastern » Tue Feb 13, 2018 7:31 pm
I decided to fix the short-circuit on one of the points. The layout is DCC with electro-frog points; old school with Peco PL-10 and PL-15 switches. It was a little difficult to try and work under the baseboards. I also managed to break a wire connection which involved getting out the soldering iron. :roll: A quick dab of hot solder and all was well. As I continued to tinker with the PL-15, the round piece of plastic tube fell off which is affixed to the PL-10 metal rod which move the point blades. However, the point now works and the short-circuit is gone! These things are sent to test us!
William S Gilbert
__________________________
Charles
Eastern
Re: East Cheltwell
Postby Eastern » Tue Feb 27, 2018 5:10 am
I am continuing to 'refresh' some of the layout - the embankment beyond the signal box now looks a little greener, but probably needs some variance in colour!
I also re-did some grass/hedges, though from this picture, it looks a little hairy!
and also on this lane too! - where are the scissors!
Digging through some boxes, I also found an old Mainline Patriot Class steam loco. 'Illustrious' 45532 - I haven't got round to chipping this locomotive, although it does run well. Nice and shiny too, but probably with old nylon gears and a split-chassis -
Lastly, and not to scale, I went to San Francisco last weekend and rode on the famous cablecars - something I haven't really seen modelled - it is pretty amazing how they work. Under the streets, there is a continuous cable running all the time in a massive loop. The operator in the cable car connects the cable car to the wire with a grabbing mechanism and off they go, releasing the wire when they have to slow down or stop.
William S Gilbert
Charles
Re: East Cheltwell
Postby Mountain » Tue Feb 27, 2018 10:50 pm
I have a little model of one of those somewhere. Is in H0 gauge. I slightly adapted it to go round curves as the model wasn't built to run on curves. I realize the prototype didn't like curves!
Eastern
Re: East Cheltwell
Postby Eastern » Sat Mar 10, 2018 9:29 pm
It's been a productive week at East Cheltwell - My 4MT Fowler 2-6-4 had been in a drawer for the best part of a couple of years after it appeared to be suffering from running issues and a short-circuit. I removed the engine and ensured it was totally isolated (which I suspect was perhaps part of the short-circuit issue?). I was going to use a Digitrax DH126D decoder I had , but there wasn't enough room so I opted for a much smaller DZ123 instead.
Of course , I had a 'helper' as well!
Finally, after double-checking everything, I test ran and all was well. It was still a little hesitant on the layout. I adjusted the CV2, 5 and 6 values and probably the best thing was to clean the wheels; it really does make a difference to have clean wheels and clean track!
and here she is - a very smooth runner!
I also took the liberty and lubricated the running gear. Two shots - with slightly different exposures.
It was a nice day for doing some cleaning and running trains!
William S Gilbert
Charles
manna
Re: East Cheltwell
Postby manna » Sun Mar 11, 2018 4:20 am
G'Day Gents
Fowler's are an impressive loco, can the cat solder ??? :lol:
manna
Eastern
Re: East Cheltwell
Postby Eastern » Mon Mar 19, 2018 12:58 am
I have been working on a couple of projects over this past week or so - I decided to take the plunge and try some weathering and really to see how things turn out - my subject was the rather shiny 4MT Fowler 2-6-4. I started with a spray of dullcote and then tried different weathering powders and experimented with some washes. It appears the 4MT jumped the tracks and went rallying! :shock:
Still some work to be done -!!
I also dug out some locomotives that haven't seen the light of day for a while - one a Hornby R 852 Ivatt Class 2 which I got of Ebay sometime back - It is practically brand-new and runs fairly well for its age -unfortunately, it's in that lurid green!
I also have an old 7MT John O'Gaunt which came via Ebay from a trainpack.
This is one of those older tender-driven ringfield models, but runs quite nicely. Having a spare decoder (Digitrax DH126D) I spent this afternoon chipping it - There seemed to be quite a few separate wires from the tender pick-ups as well as the connection with the engine; however, once the capacitor was sipped off, everything came together pretty well.
I had read about some perils with the older ringfield motors, but this seemed very straight forward. It's nice to have another large engine!
and another picture, just because!
Next - I have ordered some point levers and ground signals as well as having a look at the Peco (static) point rodding to add some detail to the layout - was wondering if anyone has used the Peco point rodding?
William S Gilbert
Charles
dan8400
Re: East Cheltwell
Postby dan8400 » Mon Mar 19, 2018 8:22 am
Hi,
There is some lovely work going on here! I like your weathering. Some locos would have been in a right state, especially towards the end of the steam era.
The scenery you are doing is very impressive too. Lots of nice little scenes. I like the overgrown siding in one of your most recent photos.
Do you have friends into 'railroading' over there? I imagine it being quite interesting comparing notes between the two countries.
Anyway, keep up the good work
Dan
Ex-Pat
Re: East Cheltwell
Postby Ex-Pat » Mon Mar 19, 2018 10:42 am
dan8400 wrote:Hi,
I quite agree - although once you start weathering then you've got to keep going or the nice pristine ones look out of place!
You have some lovely flows to the trackwork.
Is your local model shop Tammie's at Beaverton? I took a trip out there a few years ago and bought some track weathering pens and paints.
Incidentally yours is probably my favourite signature line.
Eastern
Re: East Cheltwell
Postby Eastern » Mon Mar 19, 2018 7:41 pm
Thanks Gents! - there are quite a few "Model Railroad' clubs in the area - including the massive Columbia Gorge layout - (Click here) - I often visit WhistleStop Trains and The Hobby Smith which are my local model shops - great for scenic supplies and decoders, but everything else is ordered online.
William S Gilbert
Charles
the weston guy
Re: East Cheltwell
Postby the weston guy » Wed Mar 28, 2018 3:57 pm
Was very happy to see pictures of this layout again!
I have used the Peco point rodding and it's a little fiddly to install but really improves a layout. Maybe plan out how you are going to install the rodding, where you need expansion joints etc. This can all be found online. The only issue I can see is that having already ballasted it will take you more time to install.
Eastern
Re: East Cheltwell
Postby Eastern » Thu Apr 12, 2018 2:27 am
Thanks Tim! - Yes, it looks like it is fiddly, but will probably add some realism. On that, I purchased these:
and fixed it next to a point - later realizing how the tabs from the PL-10 point motor stick up!
Something to think about when doing close-up pictures.
I recently bought an old Hornby R338 Class 29 for the princely sum of £23. For a model made in 1982 or about 35 years old, it seemed to be alomost untouched and looked bran-new. Obviously there are faults with the headcodes over the front doors, grills and chassis - let alone the motor, I always had a soft spot for a 'Sad-Eyes' Class 29
I was pretty impressed the wheels looked like they had hardly any run time - but have the dreaded traction tyres.
Next is to convert to DCC - nice looking loco - just wished I had checked the buffers were straight before taking any pictures! :shock:
I am still working on refeshing scenery and taking stock of what needs doing - this is an underdeveloped part of the layout and perhaps should remain so.
perhaps a slight greening up and a fence or hedge?
William S Gilbert
Charles
luckymucklebackit
Re: East Cheltwell
Postby luckymucklebackit » Thu Apr 12, 2018 8:35 am
Hi Eastern - There have been some saying that the lower body moulding (bevelled turnunder of the bottom of the body side, and fairing around the ends from the buffer beam) is more accurate on the old Hornby model than on the samples for the new Dapol model. If you waned to improve it there was a Monty Wells article in the Railway Modeller a good few years ago that shows ways to improve the model and I am told that the Bachmann class 25 chassis can be adapted to go under it. I have a copy of the article if you are interested.
Personally I have two that are hard wired to run together, the improvement in performance is amazing as you have eight wheel pickup instead of four.
Eastern
Re: East Cheltwell
Postby Eastern » Thu Apr 12, 2018 6:56 pm
Thanks Jim - Thanks for the offer and info - I have read up on several articles particularly using the Bachmann 25 chassis on RM Web. Currently, it is a great runner, but needs more pick-ups - I would be interested to see a picture of the two you have hard wired together.
William S Gilbert
Charles
luckymucklebackit
Re: East Cheltwell
Postby luckymucklebackit » Thu Apr 12, 2018 9:40 pm
Hi Eastern - here are a couple of shots of the locos, the wiring is quite simple, the feed wires to the motors are bridged
I have three pairs of older locos done this way and it works well, the 2 x 29 pairing, a Lima 26 and 27 pairing and a Hornby 25 and 24 (converted 25) pairing.
Hope this helps
Eastern
Re: East Cheltwell
Postby Eastern » Sun Apr 29, 2018 10:43 pm
Hi Jim- meant to thanks for the pics :oops: Our Oil furnace (boiler) decided to stop working permanently after 61 years and so we have been working with the contractors and electricians and gas men to upgrade the whole system to the 21st century! We just have to decommission the 675 gallon tank buried in the back garden! Provided it hasn't leaked :shock: It usually is filled with a mix of slurry and sand and then left in place. Ah - the joys of homeownership which detracts from working on the layout!
I have been working on that piece of open grassland and generally cleaning it up - really there should be a fence to stop trespassing on the railway, but I have started with a hedge. The base is some polyfibre and a little scatter as well as some static grass - (and some smelly hairspray!)
I also acquired a rather nice Hornby R2249a 2-8-0 8F for the princely sum of £37 which seemes like a good deal - it is practically brand-new with a bag of detail parts to add (and of course a decoder at some point) I have leaned towards the Western region, so its a refreshing change! It looks like the 'doors' need closing!
Have a good week to all!
Sunny afternoon!
William S Gilbert
Charles
Users browsing this forum: No registered users and 75 guests
