6x4 Starter layout - For sale?
smallman28
Re: 6x4 Starter layout - Upper level
Postby smallman28 » Thu Jan 14, 2010 9:11 pm
I like the upper level,almost gives me an idea for my new N gauge layout :twisted:
Unless I missed it in reading is the upper section done on some kind of foam base?
egroeg93
Postby egroeg93 » Thu Jan 14, 2010 9:43 pm
The original layout in the first pictures I thought looked very professionally planned, I liked it a lot and I like what your doing with it even more.
jamest
Postby jamest » Thu Jan 14, 2010 10:07 pm
smallman28 wrote:I like the upper level,almost gives me an idea for my new N gauge layout :twisted:
Hi - yes the base is two layers of finest insulation foam from wicks. I can't remember the trade name now - its something like celotec or something. It has a silver foil lining on the faces which I removed. It is a little difficult to stick together but it kept the whole thing light and it is very easy to form with a knife.
If I did this again I might consider splitting the board - despite my efforts it is quite difficult to move alone - and I'm 6'8" tall!The wife is getting better at helping me lug it around though!
James
Hammy
Postby Hammy » Fri Jan 15, 2010 9:19 pm
Wow, what a fantastic little setup!
makes me wish i still had my 6x4!
i really like the raised up depot in the middle. its a layout on a layout!
and the use of scalescenes :wink:
jamest
Re: 6x4 Starter layout - Upper level - new pics
Postby jamest » Wed Jan 20, 2010 8:21 pm
Hi again,
Little more progress on the upper level.
I have decided to cheat a little and I have bought a ready to plant refuelling point from the scenecraft range. I have attached some power to the upper level and made a hole in the back scene which will lead to the upper storage area. I've run my class 20 around it, where I can, to test and everything seems to be fine - I've just got to cut and place the correct length sidings now.
I used dowels to control the lower level scenic points but on a recent trip to Exeter I saw some wire and tube on sale - so I thought I'd give it a try. The wire is very thin but remarkably effective when housed in the tubing, even when you are 'pushing' the point. The tube is PTFE and is flexible so you can bend the line to suit the surroundings. At £10 For two packs of wire and two packs of tube (6 metres in total) its pretty good value in my opinion.
Enough with the talk and on with the pics:
New refuelling point
20jan10- 001.jpg (76.31 KiB) Viewed 1820 times
20jan10- 002.jpg (60.58 KiB) Viewed 1816 times
Exit to upper storage (notice point wire and sleeving)
20jan10- 006.jpg (70.52 KiB) Viewed 1817 times
20jan10- 003.jpg (65.69 KiB) Viewed 1818 times
Overall view of upper level - sometime I'll try to photograph it in the daylight!
20jan10- 005.jpg (71.03 KiB) Viewed 1818 times
James
jamest
Postby jamest » Sun Jan 31, 2010 7:27 pm
Hi all,
Right - bit more progress 'behind the scenes' and this time I've managed to take some photos in daylight!
I had a rethink on the fiddle yard and managed to get in a siding that I could enter from either direction. But the siding wasn't big enough to take an engine and three coaches so I added little headshunts at each end so I can enter, go to the end to clear the back point, reverse into the opposite headshunt, and drive out again when I want. It really makes a difference when you are operating the layout. I've also offered up the upper level fiddle yard but nothing is 'nailed down' yet.
jan31 001.jpg (84.64 KiB) Viewed 1818 times
jan31 003.jpg (68.22 KiB) Viewed 1814 times
jan31 002.jpg (80.78 KiB) Viewed 1816 times
I've also changed the 4 scenic points at the signal box end to solenoid control. The dowels were damaged when I moved into the conservatory for winter (sod's law dictated I rested the layout on the end where they were sticking out!). They are also a bit stiff and you cannot operate them from the front because of that - sometimes my son is out front and likes to use the hand of God - he can, if he likes, with point motors. I've also soldered the power wires to the track to replace the hornby power feed - well out of sight so you can't see the quality!
Here is my high tech control panel:
jan31 004.jpg (75.61 KiB) Viewed 1814 times
And heres my attempt at a 'real life' shot!:
jan31 006.jpg (66.81 KiB) Viewed 1814 times
James
smallman28
Postby smallman28 » Sun Jan 31, 2010 7:44 pm
I like the hidden top section,so much so I might steal that idea :oops: and dispense with my plan for a gradient.
craw607
Postby craw607 » Sun Jan 31, 2010 9:06 pm
Hi james
The layout is coming on leaps and bounds some good ideas there.
John
Road Stone
Postby Road Stone » Sun Jan 31, 2010 10:40 pm
Very interesting to see what can be done with limited room, the upper level is very clever. I like the retaining walls, are they Scalescenes?
Cheers, Jerry
I know Nothing!
1djspikey
Postby 1djspikey » Sun Jan 31, 2010 11:00 pm
WOW you done a pretty tidy job there keep it up :wink:
villan
Postby villan » Thu Feb 04, 2010 7:20 pm
I think your layout is really coming on. I like the added height and the fact the loop is hidden. Thats a couple of things I wished I'd done with mine.
Some nice work with Scalescenes as well.
How do you find the Select controller?
Life is good; live it to the full :wink:
See my layout at http://www.newrailwaymodellers.co.uk/Forums/viewtopic.php?f=22&t=13205 - comments welcomed
jamest
Postby jamest » Fri Feb 05, 2010 7:18 am
Hi Villan,
I am very happy with it - I got it with my first 'set' the hornby pendolino but I think you can pick one up for around 40/50 quid on ebay. My friend recently got the bachmann EZ basic controller and in my opinion it is nowhere near as good. The horndy has an aux power output for accessories and you can number a loco from 01-99 (the baccy only does 1-10). You can have around three trains running at once with lights, but any more and performance struggles a bit - but thats plenty for most people.
I also have a bachmann dynamis wireless controller because I started in the garage before I set my sights a little lower on a 6x4 to 'learn' railway modelling. That has a higher amp output and a few more features but the only real advantage is the 'wireless' capability. But if you 'hide the controller from the reciever (like putting yourself in the way!) for 10 secs or so, the trains will stop- I can see why, but it gets annoying.
If you are looking for a start in DCC I would reccomend the select - it is easy, cheap and it will be a while before you out-grow it. The EZ one is only slightly cheaper but no where near as good.
Hope this helps,
James
trainsandco
Postby trainsandco » Fri Feb 05, 2010 8:02 pm
wow, good work there james
Keep up the good work!!
Ben
Henley on Thames in the 30's
81D & 55A
jamest
Postby jamest » Wed Feb 10, 2010 7:55 pm
Hi All,
Update on my progress over the last few days:
I have cut all the sidings to length on the upper levels and placed the pit in one line under the shed. I then masked off the business end of the points and sprayed with railmatch sleeper grime - I've still got to go around the masked areas carefully with a brush and then clean off the tops of the rails.
I've also glued up some 'sky' paper on the backscene and started on my 'bridge' over the entrance. I have used my scalescenes retaining wall prints to come up with my walling on the backscene and I'm pretty pleased with my efforts so far.
I've also stretched my era further by purchasing a two-tone green class 47 from ebay! Couldn't resist!
Here are some piccy's:
Painted track & blue backscene:
feb10 003.jpg (66.98 KiB) Viewed 2032 times
New bridge! I plan to have a wall spanning out at the lower height across the backscene:
feb10 006.jpg (67.49 KiB) Viewed 2029 times
feb10 007.jpg (56.16 KiB) Viewed 2029 times
My new baby!
feb10 005.jpg (58.37 KiB) Viewed 2027 times
James
trainsandco
Re: 6x4 Starter layout - new pics
Postby trainsandco » Wed Feb 10, 2010 7:59 pm
wow good work!
81D & 55A
Users browsing this forum: bootneckbob and 20 guests
