Crayholt
richrailway
Crayholt
Postby richrailway » Thu Jun 04, 2009 9:10 pm
Since thinking about building a railway since last year, I haven't had the chance due to work and pesky deployments so now I'm in a position to start.
I've used the layout Bredon from the peco set track plans book as detailed in the under construction thread and I'm building it in the era of late 70's corporate blue BR under the layout name of Crayholt.
I started on the construction of the baseboard, it's a softwood timber frame with a 44mm square beam running in a cruciform in the middle with a glued cross halving joint to give the frame strength. The baseboard top is constructed in sundeala, I know a lot of people hate it but I've used it before and I quite like it as long as its well supported and adequately screwed down. I also give it 2 coats of emulsion to seal it. Also the layout is in a room in my house so won't be subjected to extremes of temperature or humidity.
With the baseboard prepared the track has been laid but not pinned into place, the layout is a mixture of my old track that was taken from a layout I had 20 years ago and some new stuff that was bought recently. The contrast between the new track and the old track is quite obvious so I'm thinking of applying a paint wash on the rail sides to tone the new stuff down to match the older rail.
So that brings me up to today, I've spent today soldering tails onto the point motors, of which I also had left from the old layout too.
I also made a template out of aluminium sheet for the hole I need to cut to fit the point motor in a baseboard, the template also has two holes in it that allow me to drill holes in the baseboard so I can solder copper dropwire directly to the underside of the track so they will be hidden whent he track is ballasted down later. Since I'll be going for a DCC system I need a few dropwires to cover the whole layout.
Because rules are rules. Where would we be without rules, that's right FRANCE!
Sprintex
Re: Crayholt
Postby Sprintex » Thu Jun 04, 2009 9:50 pm
Only just started and the HST is out on track already - good man!! :wink:
ste234
Re: Crayholt
Postby ste234 » Thu Jun 04, 2009 10:00 pm
Sprintex wrote:Only just started and the HST is out on track already - good man!! :wink:
:roll: how typical of you Paul eh... :wink: :lol:
Its not in your colours though is it :lol:
Richrailway nice start there, looks like a decent run of track :)
Ste.
Re: Crayholt
Postby Infrontcat » Fri Jun 05, 2009 2:47 am
I must admit, it's a mandatory requirement in my household. If the 125 don't like it, it's history :)
Good to see another Corp Blue layout on here and I look forward to seeing it develop. Got any ideas as to the scenery you're gonna add or is it very much a case of 'cross that bridge when we come to it' for now?
Cheers fella
hobby boy
Re: Crayholt
Postby hobby boy » Fri Jun 05, 2009 6:36 am
richrailway wrote:With the baseboard prepared the track has been laid but not pinned into place, the layout is a mixture of my old track that was taken from a layout I had 20 years ago and some new stuff that was bought recently. The contrast between the new track and the old track is quite obvious so I'm thinking of applying a paint wash on the rail sides to tone the new stuff down to match the older rail.
Could we have a trackplan available so we can see a birds eye view of all the track?
Hobby boy
(EDIT - quote cut down as Raider doesn't like me having quotes not relevant)
iankemp
Re: Crayholt
Postby iankemp » Fri Jun 05, 2009 9:04 pm
richrailway wrote:
just a thought on this instead of cutting a hole for the point motor, just cut a slot big enough for the point rod to slide through so it moves side to side. All you would need to do it mark out where the point slide is going to be located and then drill a small hold then cut a slot. Just a thought that is! i think it is so much easier than cutting a hole for the motor.
hobby boy
Re: Crayholt
Postby hobby boy » Fri Jun 05, 2009 9:08 pm
iankemp wrote:
I think he is going to cut that hole out in the board because he is to have the point motors directly attached to the point.
Hobby Boy
richrailway
Re: Crayholt
Postby richrailway » Fri Jun 05, 2009 9:52 pm
richrailway
Re: Crayholt
Postby richrailway » Fri Jun 05, 2009 11:09 pm
I had a box of Peco Point motors salvaged from another layout, bearing in mind they would have cost me about £40 to buy new ones with the longer pin it made sense to reuse the ones I had. They mount directly to the underside of the point and require a card shim to be mounted between the point and the motor to stop the ballast material from falling down the hole.
I've fitted all the motors on the mainlines all 10 of them and all I need to fit is the 3 for the sidings.
I also fitted the drop wires for the the DCC bus so all parts of the layout is powered at all times I probably overdid it slightly but I'm aiming for a degree of reliability, something that comes with my job or it would if I was in charge, instead we get the cheapest stuff at the highest price!!
I soldered solid copper wire on the underside of the track so when the track is ballasted the wires will not be seen.
I'll be spending the next few days finishing off the installation of the point motors and wiring up the DCC bus under the layout. Also I'll be bringing all the point motor wires back to the front of the layout. I have an old computer desk which I scrapped and I've made a frame to hold the keyboard drawer so that it can be pushed under the layout when not in use and thus out of the way.
There is a scene break to be fitted at the back of the layout to hide the run around loop, when fitted I wont be able to see what is going on so I have a small colour TV camera I acquired years ago and a 5" LCD monitor I've got so I'll be able to see what is going on, I could use a mirror but I'm flash.
hobby boy
Re: Crayholt
Postby hobby boy » Sat Jun 06, 2009 8:32 am
richrailway wrote:I had a box of Peco Point motors salvaged from another layout, bearing in mind they would have cost me about £40 to buy new ones with the longer pin it made sense to reuse the ones I had. They mount directly to the underside of the point and require a card shim to be mounted between the point and the motor to stop the ballast material from falling down the hole.
Point motors attached directly to the point is much more reliable than when it has an extended pin.
Great idea with the cctv camera, i'll put one in my tunnel (when it's built)
Hobby Boy
bsa77
Re: Crayholt
Postby bsa77 » Sat Jun 06, 2009 10:36 am
hobby boy wrote:Point motors attached directly to the point is much more reliable than when it has an extended pin.
Hobby Boy
I disagree with this having used both methods in OO and the extended pin (seep motor) method in N. I found that the extended pin type tend to be a lot more reliable when the layout is ballasted and a damn sight easier to replace if they do die.
Each to their own I guess!
hobby boy
Re: Crayholt
Postby hobby boy » Sat Jun 06, 2009 3:55 pm
Hobby Boy
depends what every one is used to. I have used both methods and they are as reliable as each other.
Hobby Boy
bigbob
Re: Crayholt
Postby bigbob » Sat Jun 06, 2009 4:01 pm
"Point motors attached directly to the point is much more reliable than when it has an extended pin."
"depends what every one is used to. I have used both methods and they are as reliable as each other."
Make your mind up Nobby Boy :roll:
bsa77
Re: Crayholt
Postby bsa77 » Sat Jun 06, 2009 4:07 pm
From the great Prophet, Mr Homer Simpson - Doh...
:roll:
hobby boy
Re: Crayholt
Postby hobby boy » Sat Jun 06, 2009 4:08 pm
bigbob wrote:"Point motors attached directly to the point is much more reliable than when it has an extended pin."
well it is a bit more reliable than the extended pin as you cut a big hole. I got my extended pin motor more reliable by getting it better in line (it was hard!!!!!)
But all together at the end of the day when their working they are just as reliable as each other.
Hobby Boy
