first layout
first layout
hi, just a few pics of my layout in progress, a lot to do yet but at least the track is sorted i hope as i've allready ripped it up twice!
i started in jan this year after recieving a set from my partner on my birthday. its 00gauge and allthough started as an 8'x4' layout has grown to 10'x4 with the addition of a 2' folding section. the layout is designed to be taken down into four managable sections including the folding part .points are controlled via model aircraft "snakes" as can be seen in the pics and it works rather well and was a lot cheaper than using point motors.
i think i have the track as i want now and hope it looks reasonably realistic, i added a short runaround yesterday allong with an extra siding for my small engine shed and i am going to partition off the rear of the layout so the fiddle yard/trian park is out off sight leaving me with a 10'x 2.8' approx scenic section at the front
any comments/help or advise welcome.
the head shunt does work as a single wire feed was taken from the adjoining track alowing operation with the point switched
mark
mark
- Attachments
- first layout.JPG (50.3 KiB) Viewed 3221 times
Re: first layout
image showing point control snakes, just two working at the moment.
- Attachments
- pointcontrol.JPG (47.16 KiB) Viewed 3221 times
Re: first layout
great stuff, nice progress so far, keep us posted!
- NEW Website: http://bluebell-model-railway.my-free.website/
- www.shapeways.com/shops/Bluebellmodelrailwayshop
Re: first layout
i had a go making a few tree's using off cuts of wire twisted together, the one on the right is yet to recieve foliage. the smaller one on the left looks a little too round i think and was the first i made.
- Attachments
- trees.JPG (60.39 KiB) Viewed 2994 times
Re: first layout
look great to me! very realistic
- Black-Marlin
Re: first layout
Those trees are brilliant!
Re: first layout
just finnished the last of the ballasting going into the tunnel. not sure what to do with the card tunnel kit as its a bit plain, trouble is i went out and bought a bunch of card kits without actually having built one or knowing what they were like and now prefer the plastic kits
note the tunnel had to be expanded by just under an inch to allow enough clearance around the curve
- Attachments
- ballast.JPG (63.96 KiB) Viewed 2899 times
Re: first layout
great start!
love the ballasting, it heaps up just right, the first ballasting i did was good but too neat, i also just started heaping it up and it adds some interest to it.
regards
barks
regards
barks
My Layout so far...
- bizzyd6405
Re: first layout
just started looking at this thread and it looks good those trees are amazing
keep up the good work
Darren
Darren
see my NSE era layout Lordsbridge - http://www.newrailwaymodellers.co.uk/Forums/viewtopic.php?f=22&t=20810
Re: first layout
thanks, the trees are a bit fiddly to make and i need quite a few more so will just knock a few out when i get the chance.
i've just started on the scenic back board which will run the length of the layout to hide the fiddle yard.
- Attachments
- backboard.JPG (49.18 KiB) Viewed 2773 times
Re: first layout
Hi,
What you have done so far looks excellent. As others have said the tree's look very realistic. I would not be too unhappy with the first ones you did, from the shot you posted they look the business.
I know what you mean about cardboard kits. I too have discovered I prefer plastic as the walls give a better impression of depth. Also, you can have more then one attempt at weathering them
However that tunnel portal looks ok. I am sure that when you have completed the scenery in that area it will not stand out as much as you think it does now.
I am particulary impressed that you have ballasted as far as you have inside the tunnel, that is true dedication for you
Keep up the good work, I am looking forward to seeing more progress
Re: first layout
the scenic backboard completed
- Attachments
- compbackboard.JPG (54.35 KiB) Viewed 2674 times
Re: first layout
behind the scenes isnt that pretty as i had to use up scrap wood to keep the escalating costs down but hey its solid and works
- Attachments
- behindbackboard.JPG (55.52 KiB) Viewed 2670 times
Users browsing this forum: No registered users and 33 guests
