Ollie's New Layout Plan - Formerly Kidderminster
olliereading1123
Re: Ollie's current attempt at an N Gauge layout - Kidderminster
Postby olliereading1123 » Thu Sep 18, 2008 11:22 pm
SMALL UPDATE
the following image shows the revised design for the mainline fiddle yard, the yellow sections of track are what i own and the brown areas are the baseboard tops i currently have.
Here is my proposed roster for ML FY:
Through Roads:
Red - Hopefully if possible the full NMT
Green - EWS 66204 with 21 HAA hoppers
Light Blue - Freightliner 66613 with 5 pairs of spine wagons
Yellow - BR Green 47 D1500 Top 'n' Tail with Virgin 57301 'Scott Tracey' Hauling 6 Pullmans and 6 Mk2 carriages in Virgin livery
Dark Blue - EWS 66??? with 15 BYA/BRA hoppers
Brown - Freightliner 66??? with 9 HHA hoppers
Lime - Hall Class 4965 'Rood Ashton Hall' GWR Green with 4 Pullmans and 5 Mk1 carriages in Choc/Cream
Pink - GBRf 66714 'Cromer Lifeboat' with 18 PCA tankers
Purple - EWS 60052 'Glofa Twr' with 2 VGA vans, 5 OBA wagons, 1 MEA wagon and 3 MFA wagons
White - Nothing, to allow movement between teminating sidings
Termiating sidings to follow...
olliereading1123
Postby olliereading1123 » Tue Sep 23, 2008 10:34 pm
now onto through roads:
Here we go:
Red - Centro 150
Yellow - Central 158
Lime - Central 170
Blue - Chiltern 168
Orange - Virgin 221 - 4 Car Unit
Pink - XC 220 - 4 Car Unit
olliereading1123
Postby olliereading1123 » Thu Nov 13, 2008 8:52 pm
been re-designing the fiddle yard for the SVR part of the layout, and managed to include the wrong track i ordered for the old design.
as with the other part the yellow track is what i have, without the track i have use in the other plan
Ta Da
EDIT
just noticed i haven't yellowed the points for SVR pltforms and should have pointed out that this FY will be raised abobe the main line one
olliereading1123
Postby olliereading1123 » Mon Mar 30, 2009 8:55 pm
CONSTRUCTION HAS STARTED!!!!
due to a new project they are bringing in at college i have decided to use my layout as my project. this has encouraged me to start construction now so i have 1 year to complete it.
so if a mod could move this to the "under construction" section i will post the pics of the first boards
Honeywell
Postby Honeywell » Tue Mar 31, 2009 12:04 am
olliereading1123 wrote:if a mod could move this to the "under construction" section i will post the pics of the first boards
Ask and ye shall receive.
olliereading1123
Postby olliereading1123 » Tue Mar 31, 2009 5:03 pm
PICTURE TIME
now to start off with i have made a light alteration to the mainline fiddleyard as to accomodate more stock(always a good reason)
as before the brown indcates which board tops i have.
and the SVR yard plan just to remind everyone
the red circle indcates which board is shown below...
Here is the construction...
And Voila...
theese are the points that will be used...
...like this...
and now the real thing...
and with locos...
Now any thoughts??????
also i have no clue on wiring, so where abouts would i have to put insulatinf fishplates, feeds etc
i am operating the trains under DCC but the points will be probe and stud analogue
many thanks
Blaqkaudio009
Postby Blaqkaudio009 » Tue Mar 31, 2009 7:40 pm
a great start ollie! real glad to see this finally being built :D
olliereading1123
Postby olliereading1123 » Tue Mar 31, 2009 7:43 pm
finally is the word, and with only 1 year to complete it
Blaqkaudio009
Postby Blaqkaudio009 » Tue Mar 31, 2009 7:59 pm
i know you better get your skates on!
olliereading1123
Postby olliereading1123 » Tue Mar 31, 2009 8:03 pm
i know!!!!
got a lot of track to order including two of the dreaded scissors crossings
olliereading1123
Postby olliereading1123 » Tue Apr 28, 2009 10:56 pm
Not much of an update but...
- A few more of the boards have frames.
- I have renumbered an poole farish prairie from 8102 to 4150 (SVR Loco)
- I have fitted some MBM couplings to two of my wagons, very fiddly but worth it.
- Started to build a NGS Mica van kit, just got the chassis to build.
- Also got a NGS Lowmac kit which i need to build then figure out how to add the MBM's
i am still waiting for my extra points, but there will be pics soon
olliereading1123
Postby olliereading1123 » Tue Jun 02, 2009 10:04 pm
I thought i would post some images on how i am making the board joins.
to start of with i cut the wood to size, the ones shown below are two end pieces for the lowr fiddle yard boards. I first drilled a hole between the two as shown.
this hole is for one set of locaters shown below.
the first locaters are hammered into the holes then another set of holes are drilled on the other side.
and then the second se are hammered, the opposite way to the first.
next i drilled two more moles for the screw system, they made of several pieces (right) and when assembled look like the one on the left.
And the completed piece.
for £15 i get enough bits do to 5 joins, good value me thinks
Sprintex
Postby Sprintex » Tue Jun 02, 2009 10:51 pm
Same method that joins my two boards together, and seems to work very well so far :wink:
An ambitious plan, but not impossible - have a look at my layout thread to see what we achieved in 9 months without devoting every spare minute to it, and how it stands now. You may not have all the scenery complete by then, but then no layout is ever complete, there's always that "what if . . . " lurking :lol:
Good luck with it mate!!!
olliereading1123
Postby olliereading1123 » Tue Jun 02, 2009 10:55 pm
cheers sprintex,
i've been watchin your layout progress and i'm very impressed with how it's going.
I have though about the fact that i have limited time so i have a backup idea for the project which is just the station building itself as i tink it will be a lovely model, especially with that canopy roof it has.
bigbob
Postby bigbob » Tue Jun 02, 2009 11:03 pm
Some serious planning gone into that Ollie and interesting reading. Will keep an eye on this and watch it develop. Good work so far though mate and best of luck with it.
Bob
Users browsing this forum: Google [Bot] and 10 guests
