Time to Tear It Up & Start Again ! New Steam Layout Pla
DrStroganoff
Re: Time to Tear It Up & Start Again ! New Steam Layout Pla
Postby DrStroganoff » Wed Oct 14, 2009 5:39 pm
Hi Michael,
Well, personally I would recommend Code 100 rail... It really depends what kind of stock you are planning to run... As the Code 75 rail is finer than the 100, I assume that you may encounter some problems if you were to run older-type stock on it...
Also, is the layout going to be DCC controlled ? If so, then I would suggest electro-frog points, so not to isolate any sections. If you are going analogue, its all down to personal choice really.
For example, I have always used analogue control, with insulfrog points (Code 100) . And for the new digital layout, I am going to stick with Code 100 trackwork, but change the points over to electro-frog, as I want to have all of the track 'live'.
Sounds like you've got a lot of work on with your new project !! Good luck with it all ! :D
