Very nice work with the track there Zunnan, could be very useful indeed.
How did you heat the track?
Canon Street ~ N Gauge
- blooregard
Re: Canon Street ~ N Gauge
Punctured bicycle on a hillside desolate.
Re: Canon Street
SouthernBoy wrote:Out of curiosity what is your process from planning to laying track ?...
Would you believe that I didn't plan it at all in this guise until I had the chipboard laid out on the floor?
As soon as it had been drawn out, I realised just how little storage there was so added in the passing loop on Mid-Level to relocate the goods yard and widened the station to four platforms and one bay. In the era I wanted to model (Early to mid '60s), larger stations platforms still had access to all routes leaving the station, there was an article in Railway Modeller a fair while ago which had a OO layout based on Llandudno and was fairly close to what I now found that I needed so I condensed and simplified that track plan to fit the space I had available. It was this stage that the boards were built and track laying began, but the goods yard and engine shed were left at their respective entrances while I concentrated on getting two circuits running. The location of the goods yard and engine shed switched places when I obtained 20+ 16 tonners and realised that I needed the larger site for the goods yard to be able to cope with running near to scale length trains.
SouthernBoy wrote:I've just had an idea ... why don't you do something similar to Mumbles (and others I think) and set a webcam up, or series of webcams ? That would be fun - you could have like a multi-screen CCTV of your layout from favourite angles. You can get mini cameras which could be hidden between houses or something
I quite like the sound of that idea. It's certainly comething to consider
blooregard wrote:How did you heat the track?
I heated a glass chopping board in the sink to give me a flat working surface that would allow me to keep the plastic on the points workable for longer. Then I lit a burner on the cooker and held the piece being warmed over the burner at a distance which was just about bearable to my hand. Very unsophisticated I know, but I figured that if it was too hot for my hand to cope with then it could soften the plastic too much and affect the back to back measurements.
I've had a change of heart about the engine shed area. It was going to be a small affair, but after cutting the turntable in I decided that I really didn't like the curved approach roads to the turntable, nor the limited storage roads for locos on shed. So I have come up with something a little more large scale, keeping the turntable where it was...I really should have held off on the TT!
A 4 road shed, the structure based loosely on Green Ayre (Lancaster), with a long term storage siding alongside a'la Rose Grove and having a coaling facility along the back of the shed which is also to be based on the coaling stage at Green Ayre although located on the opposite side to the shed to how it was sited in reality.
Try to imagine a mirror image of this, without the turntable at the shed entrance, and you have the general idea
As an aside note, I have the full trackplan for this shed and fully intend on building it in OO/EM gauge when I have sorted the house move.
I'm so glad I redesigned the shed area, the old plan just didn't have enough capacity. And this one probably isn't big enough either!
Fifteen locos on shed graphically shows how much space is taken up even with this larger plan. The long term storage road (located between the turntable and the shed) will help matters by giving room for a further three tender locos, and the coal facility should provide for another three. Total capacity should be for around eighteen locomotives while keeping the turntable approach roads free.
Electrically I am going to wire the whole thing so that the points don't dictate the route of power, everything will be live and the whole lot will be switched for individual 6" lengths of track and points. Power routes will be dictated by the switches on the control panel allowing locomotive movements against point settings and also in sidings behind static locomotives. DCC would be easier to wire admittedly, but I am not willing to chip 20+ steam locos, a dozen diesels and rewire the parts of the layout that are already working!
- SouthernBoy
I like
What turntable have you used, or is it home-made ? Your idea of 6" track sections makes sense. Out of curiosity, would you go DCC if you were starting afresh and the cost wasn't a problem ? For me there's something 'old school' about DC which I quite like ... although that doesn't mean I wouldn't go DCC in the future. What swayed me most was I couldn't see how to get a chip in really small locos like Dapol M7s.
The turntable is just the Peco offering. It does the job, its cheap, easy to put in place, but more importantly it looks right when compared to certain more expensive motorised offerings.
To be honest, I wouldn't touch DCC with a barge pole on an N Gauge layout. I don't think that the pickup ability of the smaller locos is up to the task, it's bad enough on the larger steam locos at times unless the track is kept spotless at all times. I'm not shy in saying that I hate DCC in the main to be honest. My OO DCC experimental layout was packed away long ago, even before the house move was on the cards, and I'm still in two minds about removing the chips from all of the locos for when I can start on the loft layout I have planned. The only saving grace for DCC are the sound decoders (and I do like my Howes class 40) so that may be the ultimate decider as I'm not affraid of the wiring needed for DC on large MPDs like the one I have planned.
Just a quickie being as time is at a bit of a premium lately. Construction of the shed has begun!
Hopefully the 'face' of the shed vaguely resembles what it is supposed to. A lot of detail and definition needs adding yet but the basic structure is there, mostly to check clearances
The white and cream framework behind is the skeleton for the roof and steam chutes, and will be built removable so that I can get my hands into the shed for those moments where engines decide they don't want to budge! The roof sections are going to take a LOT of patience, I'm going to glaze them in the same way as I have seen in photos of Rose Grove and Carnforth (and no doubt many other LMS sheds)
- SouthernBoy
Zunnan wrote: ... the roof ... will be built removable so that I can get my hands into the shed for those moments where engines decide they don't want to budge!
Have you seen this Zunnan ? How to get a stalled loco going again: The County Gate Wobbler. Quite ingenious and something I'll probably try at some point. Best to still have a detachable roof though
Your shed is coming along nicely. Will you have lights (working) along the front like in the picture you posted ?
this is an awesome start, a big influence for my layout i must say.
Have you got anymore done Zunnan?
Ste.
Ste.
Affraid not, the layout is in storage while we're stuck in rented accomodation because the banks are being idiots with mortgages. Anyone would think a sizeable deposit and over £1.5k a month disposable income wasn't good enough to get a mortgage!
- 5690
- Location: Castleton, Rochdale, near a rail link to the ELR
This is looking stunning, absolutely stunning. A true inspiration, very well done!
Users browsing this forum: No registered users and 24 guests
