I love the look of the Dapol 9F, only the plastic center driving wheel detracts from the overall look (the wheel looks cheap and nasty). I'm having real problems with it though, the traction is next to non existant! My Dapol Ivatt can pull more
It's going back to Dapol themselves as they've expressed some concern in the problems I've found. A real pity, because if it ran well I'd have a couple more of them!
I forgot to add the work done to the town that will be located on the Mid-level board. The insulation board base has been topped with black card to give a nice flat surface to mount the buildings. I've made a handful of Metcalf kits and positioned them to give me an idea of what will fit where. I haven't started on the 6 foot long row of terraced houses yet...That is still scaring me!
Mid-level town viewed from across the railway by the engine sheds.
The beginning of the High Street viewed from Canon Road overbridge.
The bridge being built certainly is two parallel roads at differing levels. The upper level I will surface with a road and low relief shops as it's intended as the scenic break to hide the setrackesque curves at the end of the board, the lower road is the approach to the station and goods yard.
The bridge in the Standard 4 pics is scratch built, but it's VERY easy to make them. The girders are just glued to Daler board and reinforced with plastruct underneath and handrails added on top, shown in the pics below.
I needed to make another for the station access bridge, so took pics of the construction as I went along. In total it took an hour from cutting the pieces to having it mounted in position and primed ready for weathering, and thats including the time for the paint to dry!
The basic components. Plastruct C beam with T section for the ribbing.
The parts all cut to fit, ready for assembly.
Partially assembled using little more than a scalpel to trim the ribs to fit and long nose pliers to position them when glue is applied.
Assembled and primed.
Fixed in position within an hour! The rough black card will look far better when skinned with Scalescenes brickwork.
