Base for track
barney121e
Base for track
Postby barney121e » Sat Jun 10, 2017 2:51 pm
I have a baseboard made of wood and ply. I need to have the track higher than the baseboard. Have some polystyrene to raise height but do I need to put anything on top of this like more ply or card, or can I just put trackbed down?
Any ideas, much appreciated.
Re: Base for track
Postby Bufferstop » Sat Jun 10, 2017 3:00 pm
You could lay it straight onto the polystyrene if you are gluing it down, but it doesn't provide a good anchor for things like signal and telegraph posts, a strip of thin ply (no more than 4mm.) slightly wider than the track should be all you need. Glue it down with something like "No more Nails"
barney121e
Re: Base for track
Postby barney121e » Sat Jun 10, 2017 3:18 pm
Would balsa wood be any good?
Re: Base for track
Postby Bufferstop » Sat Jun 10, 2017 5:29 pm
I almost suggested it. I'd seal it with some varnish before track laying, you don't want it to curl when you start ballasting.
