started
started
lets se where we go
- Attachments
- IMG_20161214_215431_1[1].jpg (149.9 KiB) Viewed 3113 times
- IMG_20161214_215431[1].jpg (131.93 KiB) Viewed 3113 times
Re: started
looking good! i would kill to have mine in the house, under a nice solid roof
anyway good luck with the rest of it i am looking forward to seeing how it develops
Re: started
Good to get started - even better when the first track gets laid.
Have you got a track plan to share with us (can't find one in your Planning Section thread)?
Reading between the lines does that "middle" section suggest a viaduct perhaps?
Are those 2 protuding legs on the right going to serve a particular purpose?
Never seen pink wood before - is there something special about it?
Re: started
viaduct is a thought havent got a track plan as such thought put in the things i want ie viaduct/ bridge small harbour/river/canel then plan track around that as for the two legs being long havnt finshed leveling that side pink wood is roof batten so should last
Re: started
had a few hours tonite built valley had a go at bridge really want to build as much as poss feels more like my input
model skill low but will try any input on bridge will helpful cheers
- Attachments
- IMG_20161215_202230_1.jpg (131.97 KiB) Viewed 3063 times
- IMG_20161215_202230.jpg (129.2 KiB) Viewed 3063 times
- IMG_20161215_181604_1.jpg (157.59 KiB) Viewed 3063 times
- IMG_20161215_181604.jpg (144.46 KiB) Viewed 3063 times
Re: started
It looks good. Two methods to make the sides look real. Either cut card bricks or dressed stones and glue on, or roughen sides and apply modelling clay, scribing the gaps between the stones or bricks. Looking good.
Re: started
quick update frame finshed baseboards down and fixed had a little play any thoughts very welcome cheers
- Attachments
- IMG_20161221_183708_1[1].jpg (124.4 KiB) Viewed 3015 times
- IMG_20161221_183708[1].jpg (116.51 KiB) Viewed 3015 times
- IMG_20161221_183659[1].jpg (133.02 KiB) Viewed 3015 times
- IMG_20161216_190115[1].jpg (122.77 KiB) Viewed 3015 times
Re: started
You are progressing well. Well done!
Re: started
here is a rough plan
- Attachments
- IMG_20161227_092249[1].jpg (103.13 KiB) Viewed 2967 times
Re: started
yet another change
- Attachments
- IMG_20161228_162229_1[1].jpg (147.45 KiB) Viewed 2940 times
- IMG_20161228_162229[1].jpg (150.78 KiB) Viewed 2940 times
Re: started
Nice to see another start, it's lovely indoors isn't it
I think you may have your arch set a bit too low for your viaduct. Here's mine for comparison, one of the few bits I retained from my previous layout.
Re: started
see your point might have to rethink that yes nice indoors
Re: started
glad have not rushed track plan size of baseboard reistick loco size so thought put though line at back to give me chance to have something longer plus gives me some height and make viaduct /bridge more relistick sorry about spelling
- Attachments
- IMG_20170105_200623[1].jpg (130.13 KiB) Viewed 2902 times
Re: started
its in my head just cant translate to lay out need a push in right direrction
- Attachments
- IMG_20170112_182105[1].jpg (136.16 KiB) Viewed 2870 times
- IMG_20170105_200623[1].jpg (130.13 KiB) Viewed 2870 times
Re: started
With the two bridges (which looks good) what is the height between the two?
(Thinking whether they will end up as two separate railways, or whether major gradients, probably spirals, will need to be allowed for)
Just checking... this is in N, isn't it?
