Another question about glue and cork
muggins
Postby muggins » Mon Oct 17, 2016 3:29 pm
Actually, two questions about glue and cork, because having read several threads on here about this, I'm thoroughly confused ...
1. Am I right in thinking that PVA is no good for sticking cork sheet to plywood therefore I need to buy Copydex for that?
2. And what's my best bet for sticking Peco 00 trackwork to the cork?
Ex-Pat
Re: Another question about glue and cork
Postby Ex-Pat » Wed Oct 19, 2016 3:07 pm
Does it have to be cork?
My experience of cork is that it disintegrates over time, and that is why I use closed cell foam.
This material can be glued to plywood using PVA, and flexible track can be glued to it using PVA.
The choice is yours!
muggins
Postby muggins » Wed Oct 19, 2016 3:51 pm
Ex-Pat wrote:Does it have to be cork?
Yes, hence the question. Thank you but I found the answer elsewhere.
