6x2 baseboard
shunter-steve
6x2 baseboard
Postby shunter-steve » Tue Jun 11, 2013 6:59 pm
hi guys im using 3"x1" bracing topped with 9mm ply constructed as crudely shown below,the board will be packed away when not in use.does the board look sturdy enough to you guys.any input would be most welcome
cheers steve.
whynot
Re: 6x2 baseboard
Postby whynot » Tue Jun 11, 2013 8:28 pm
Received wisdom says, I think, max 12" spacing - but personally I reckon with 9mm top the nearer 18" (by 12") that you plan would be fine. Opinion only you understand!
dave j
Works End 0 16.5
viewtopic.php?f=22&t=49336
craw607
Re: 6x2 baseboard
Postby craw607 » Tue Jun 11, 2013 9:54 pm
If you are unsure of strength you could always add L shape brackets to all joints.
John
Pete
Re: 6x2 baseboard
Postby Pete » Tue Jun 11, 2013 10:26 pm
I tend to go for 2x1 with 400mm centres, so about 16", with anything from 6mm-12mm top boards.
3" should take a 1:1 model of the Titanic :|
Pete
It's the nature of evolution
The dinosaurs went to Hell
shunter-steve
Re: 6x2 baseboard
Postby shunter-steve » Wed Jun 12, 2013 12:41 pm
thanks for the input guys ,on with construction.
steve.
