N gauge newbie
Re: N gauge newbie
Beware track curve radius. Do not use first radius curves (the tightest ones), as these are too tight for many steam locos, and most locos have a warning in the instructions that they perform best with second radius and above. You can get away with the tight settrack points though some locos stumble a bit on those too sometimes. This will be particularly important when planning your nested loops , as the inner one must use the second radius curves (or flexi bent to the same radius), with the ones outside at progressively larger radius. You can buy track setta guides at the various radii to help set your track curves, or buy a couple of second radius settrack pieces and draw around them to set your tightest curves.
Re: N gauge newbie
How many accessories can i use with a gaugemaster combi controller..
Re: N gauge newbie
Wat are the r8250 controllers like to use and are they for n gauge
Any ideas would be greatfull.
Re: N gauge newbie
I have recently given a Class A3 4-6-2 60052 'Prince Palatine' in BR Green but need a set of smoke deflectors.
Can anyone help me please.
Many thanks
Many thanks
- Ironduke
Re: N gauge newbie
I think I'd try my hand at making some out of tinfoil or similar if it was mine.Michaelreedy71 wrote:need a set of smoke deflectors.
