Farish 4MT 2-6-0 issue's
markS&D
Postby markS&D » Fri Mar 16, 2018 7:49 pm
Hi folks, posting on behalf of my father again.
My father recently purchased the Farish BR class 4 mogul. Looks great, however it has an issue that appears to be a design fault. The locomotive has a ridiculous amount of coupled axle side play, which is causing the valve gear to lock up. Basically the leading coupled axle crankpin hits the rear of the cylinder slidebar assembly, when the locomotive changes direction.
Short of putting some sort of plastic spacer between the wheels and the chassis, we cannot see any way of rectifying the problem.
Has anyone else had this issue?
My layout, only look if you are interested:
viewtopic.php?f=22&t=48422
Latest Video Link:
https://youtu.be/g5ytOK5FCZc
Bramshot
Re: Farish 4MT 2-6-0 issue's
Postby Bramshot » Sat Mar 17, 2018 10:25 am
I have had loads of issues with coupling rods on new locos, sometimes the wheels seize, I have had a problem similar to yours and managed to slightly bend things to obtain clearance. Is the crank pin actually fully screwed in? I have had loose ones. There usually is quite a bit of sideplay to allow the locos to get round bends that are so much tighter than true scale.
I would send it back. If it came from H you will get a replacement sharpish.
I have had probs with probably 50% of the steam locos I have bought! Quality control is awful.
Thinking on, I did have one of these and it was sent back, I think because of jamming wheels. I changed it for an N Class, which runs nicely.
