The only controller, I have is from the Hornby Christmas set.
It is the silver/black one.
The small red locomotive from the set runs well. Also had a success with a 90's 8-wheel drive Bachmann and 90's 8-wheel Walthers - both running slow but fairly smooth.
Recently acquired 2 spares/repairs: single pancake Tyco and a 4-wd tank Airfix, Done a full service. Both locomotives would only move a few inches and stop, sometimes just buzz and not move at all. I questioned my ability to bring them back to life.
Connected a 9V battery to track.
Both locomotives run so smooth and beautiful on the 9V battery and seem to be faster than the max "14V" from controller.
Is it a dodgy controller or is it the quality of it?
how good is the Hornby silver/black controller?
Re: how good is the Hornby silver/black controller?
Its relatively low powered output causes many issues.
There are far better (probably more expensive!) DC controllers available, that do not suffer this issue. Gaugemaster and Morley are two makes
- Roger (RJ)
It's rubbish. Invest in a Gaugemaster for (almost) total reliability and a lifetime guarantee.
Worse than useless. Trips out at the slightest hint of a short and takes ages to reset itself.
- Dalerailman
Silver/black no good many other controllers H&m before hornby versions like duette and clipper really good controllers. The output of he later controllers does not go well with older trains I found with Hornby 2000 controllers x-04s used to smoke and stall and hum a lot more than the old H&M Clipper i had at the time. anything at 14v is not good for 12v also. if do stick a loco on uncontrolled 16v be prepared for a small fire I have seen the result on a terrier which was a mess
The controller you mention does work for lower powered locos and it looks as if it should be good BUT after having had one for a bit, it is so horrible to use due to its over-safe safety features that I did not even want to use it to test trains with. Get a Guagemaster and buy a nice one. They are a luxury that is worth paying out for.
Mine broke in a week......
I suppose that sums it up.
Someone is stealing wheels from Police cars, The Authorities are working tirelessly to catch them.
