Laying track in warm weather
mjb1961
Postby mjb1961 » Tue May 14, 2019 5:37 pm
Hi ,,,,could someone just confirm that if laying track in warm weather you should leave a small expansion gap ,,,,I can't remember if you do or don't ,,,thanks mjb
Roger (RJ)
Re: Laying track in warm weather
Postby Roger (RJ) » Tue May 14, 2019 5:51 pm
Leave a gap in cold weather to allow room for the rails to expand when it gets hot.
So, in hot weather, the gaps should be closed up. Perhaps leave a gap the thickness of a piece of printer paper when laying track in warm weather.
mjb1961
Postby mjb1961 » Tue May 14, 2019 6:24 pm
Thanks Roger ,,,,mjb
Postby Bigmet » Wed May 15, 2019 8:21 am
Indoors or outside should be added as a consideration. Direct solar heating can raise the temperature well above ambient, so if laying outdoors in warm weather I would still leave a 1mm gap for the blazing hot day. (UK blazing hot, local knowledge required for those who live in a furnace heat location.)
allan
Postby allan » Thu May 16, 2019 12:08 pm
Lay your track in hot weather - 45-48°C works well here in Adelaide. Solder melts quickly, too!
Well, maybe it doesn't have to be that hot, but take precautions if you're laying track in cold weather.
