Soldering Station
Soldering Station
Postby Bufferstop » Tue Apr 24, 2018 9:10 pm
My soldering station has gone beserk, doesn't shut off when it reaches the set temperature, then bleeps like crazy when it's about 50 degrees over. Time for a new one methinks, anyone got a recommendation, mainly used for wiring and turned bit of metal to be joined, but the ability to turn it down for alloys and white metal is useful.
Re: Soldering Station
Postby End2end » Tue Apr 24, 2018 9:20 pm
Weller all day everyday.
Postby TimberSurf » Tue Apr 24, 2018 10:41 pm
If the iron lead has more than two wires, it is temp controlled by a sensor in the tip, you could test and then replace only the iron if it is faulty. I am with with above, weller are like rolls royce in style/technology/durability and PRICE! However, I have not heard bad things about most of the competition, the one I have seen recommended is a GOLD, as sold by Maplin, if you hurry, you might get a deal!
P.S. I used weller stations when I was a pro, I have the mains ones at home and still going 20 years after I got them (50W 230v and 50W 110V and a 45W 24vdc I use everyday), and all parts still replaceable :D
Peterm
Postby Peterm » Tue Apr 24, 2018 10:49 pm
I had the same thing happen with my Goot brand iron. The heater/sensor was the cause, so I replaced it and also bought a new multi meter with temp sensor to calibrate the new part. Much cheaper than a new soldering station.
Postby Bufferstop » Tue Apr 24, 2018 10:57 pm
It's reading the temperature ok, it's just not regulating, Goes on getting hotter even after it starts beeping at 50 degrees above the set temperature, so I think it's the switching rather than the sensing or heating that's the problem.
alex3410
Postby alex3410 » Wed Apr 25, 2018 8:01 am
i opted for 60W Mains LCD Solder Station from Maplin the reasons: price & availability of spare parts
the good news is its on offer at 30% off so is now £45.49, the bad news it looks like Maplin are shutting down and the 30% off is due to its closing down sale - there foes the availability of spares :twisted:
Tricky Dicky
Postby Tricky Dicky » Wed Apr 25, 2018 9:32 am
alex3410 wrote:i opted for 60W Mains LCD Solder Station from Maplin the reasons: price & availability of spare parts
Looks like the spares for it have sold out so no chance of stocking up - just in case :evil:
Richard
windcutter9f
Postby windcutter9f » Sun May 27, 2018 4:12 pm
Enter Hakko tips in the Ebay search bar,these fit the Maplin soldering iron.
Ray.
Postby Mountain » Sun May 27, 2018 4:20 pm
I have the slightly older Maplin soldering station. I managed to get spare tips at half them all in price before they closed. Glad I did as the tip that comes as standard comes to a point, where I wanted a flatter tip for the possibility of soldering tinplate.
The tips for mine are just ordinary metal tips. Not cheap even with 50% off.
Users browsing this forum: 4472 and 6 guests
