Improving point switch blade contact
clivef5915
Postby clivef5915 » Tue Jan 22, 2013 9:52 am
Hi all,
I'm sure I've seen something about this somewhere but I'm blowed if I can find it (or am I dreaming) It's to do with improving electrical contact on Peco points between the switch blade and the stock rail. Is it that a small 'spring' (similar to the overcentre spring) is placed between the two rails at the heal? Have a look at Brian Lamberts sketch which will probably show it better than I'm describing it. http://www.brian-lambert.co.uk/Electrical.htm#Points
Or is there another way which will improve electrical continuity other than relying on switch blade contact?
Ps - all track work is down and ballasted so anything to be done will have to be from above as it were.
Cheers in anticipation
viewtopic.php?f=22&t=40184/Bath Queen Square - as never was !
Re: Improving point switch blade contact
Postby Flashbang » Tue Jan 22, 2013 11:17 am
On Insulated frog points you can add two Hornby digital clips (8232) per point. These make a connection between stock rail and the adjacent closure rail. These then remove reliance on the actual point switch blade making connection onto its stock rail when closed together. These are designed to be really used on DCC (Digital) layouts where the normal self isolating feature of Insulated frog points isn't required. http://www.hornby.com/shop/digital/r8232-hornby-digital-electric-point-clips/
A similar thing can be done by soldering two link wires underneath the point, one wire link on each side, bonding the stock rail to its adjacent closure rail.
If this is carried out on a dc powered layout the unset direction will become live all the time.
However if you wish to improve the reliability on insulated frog points by carrying out either of the above conversions you can then add Insulated rail joiners onto the points Vee rail ends and then install new dc rail feeds after the IRJs These new feeds coming via a simple On/Off switches, so as the rail beyond the IRJ can then be isolated by operating the switch as required!
luckymucklebackit
Postby luckymucklebackit » Tue Jan 22, 2013 11:21 am
Flashbang wrote:Hi
The soldered wire as described by Flashbang is what I have used throughout my layout and I can vouch for its effectiveness.
clivef5915
Postby clivef5915 » Wed Jan 23, 2013 9:07 am
Thanks for the info. Will give the Hornby clips a go to begin with.
Ta
clive f
flying scotsman123
Postby flying scotsman123 » Wed Jan 23, 2013 5:55 pm
Anyone got any ideas what to use for the old hornby points, as the whole thing moves, rather than just the lower half as with odern ones
luckymucklebackit
Postby luckymucklebackit » Thu Jan 24, 2013 7:16 am
flying scotsman123 wrote:Anyone got any ideas what to use for the old hornby points, as the whole thing moves, rather than just the lower half as with odern ones
Go with the wire bridging between the two rails as described above, it will work just the same for old Hornby points.
flying scotsman123
Postby flying scotsman123 » Thu Jan 24, 2013 4:22 pm
Ok thanks
Users browsing this forum: Google Adsense [Bot] and 6 guests
