Re: BARGAINS!
BuffyMcBuffer
Re: BARGAINS!
Postby BuffyMcBuffer » Thu Jul 12, 2018 2:41 pm
Emettman wrote:Would give an 18" industrial line in 4mm scale
??? Could you elaborate on this more please what’s 18” Industrial line?
Re: BARGAINS!
Postby Emettman » Thu Jul 12, 2018 3:19 pm
A large range of industries used narrow gauge lines for internal transport in a whole variety of gauges, from 12" up to 3' and larger.
18" gauge lines could be found at at waterworks, engineering firms and also at Railway works themselves, the largest being at Crewe
https://en.wikipedia.org/wiki/British_industrial_narrow-gauge_railways
https://en.wikipedia.org/wiki/Crewe_Works_Railway
https://en.wikipedia.org/wiki/Horwich_Works
https://www.google.co.uk/search?rlz=1C1GCEA_enGB790GB790&biw=1337&bih=601&tbm=isch&sa=1&ei=M2FHW9iZHIfVkwXr3IuYCg&q=18%22+gauge+railway&oq=18%22+gauge+railway&gs_l=img.12..0i8i30k1j0i24k1.5514.14010.0.16722.12.6.6.0.0.0.66.366.6.6.0....0...1c.1.64.img..0.12.394....0.6tVqJApetzQ#imgrc=7RNcdrGW7gXv9M:
Lots of different things!
Normally Z gauge power units are a lot more expensive than this item, which prompted ideas for it.
BuffyMcBuffer
Re: BARGAINS!
Postby BuffyMcBuffer » Thu Jul 12, 2018 3:33 pm
Ah I see cheers for clearing that up
Much appreciated
Re: BARGAINS!
Postby TimberSurf » Thu Jul 12, 2018 4:48 pm
I am very tempted, if it were an 0-4-0, I could think of many uses, but as a Bo-Bo, it does not fit so easily. It would essentially have to be a diesel Bo-Bo narrow gauge. :? Can't think of anything other than a touristy 18" modern attraction. But that's just me and my layout. :)
Re: BARGAINS!
Postby Emettman » Thu Jul 12, 2018 6:28 pm
TimberSurf wrote:I am very tempted, if it were an 0-4-0, I could think of many uses, but as a Bo-Bo, it does not fit so easily. It would essentially have to be a diesel Bo-Bo narrow gauge. :? Can't think of anything other than a touristy 18" modern attraction. But that's just me and my layout. :)
That's why I suggested "ghosting". It won't work on a shunting layout, but if the first coach or freight van or full ore wagon is Bo-Bo...
If you don't want to knock up some Z scale motion for the loco, it seems likely that it will need tramway side plates!
It's a quick and dirty (and cheap) approach if this is to work.
N scale bogie tram on metre gauge?
Stepping sideways, this is pure N:
Train with tiny non-powered loco, first coach having a 4 wheel power unit. £50 including postage.
https://www.ebay.co.uk/itm/Kato-10-500-2-Chibi-Steam-Loco-Coaches-NEW-Black/382515481085?hash=item590fb309fd:g:HCEAAOSwWEZaZ3G7
Re: BARGAINS!
Postby Bufferstop » Thu Jul 12, 2018 9:35 pm
For N gauge mechanisms plazajapan always seems to have a good range of units from 4 wheel bogies and 0-4-0 steam locos to long wheelbase four wheel wagons/ coaches and B0-B0 in various lengths, and nothing I would call outrageously expensive. I motorised an H0 scale Austrian tramcar, on 9mm gauge for £15, using the chassis that goes under the N scale Thomas coach.
I have a plan one day to put some 3mm scale IOM tramcars on N scale B0-B0 chasies and do a cut down Laxey on a 3 X 2 block of Kingspan insulation.
Re: BARGAINS!
Postby Emettman » Thu Jul 12, 2018 10:59 pm
I'll second that reference to Plaza Japan.
I've never had any trouble with payments or with deliveries, and their prices are usually very competitive, barring the occasional surprise bargain elsewhere (all observed from eBay.)
The Kato Bo-Bo power bogie is excellent, and is happy down to 4" radius.
It is designed for the N scale "B Shorty" range of bodies, sold as static items.
RailwayRobbo
Re: BARGAINS!
Postby RailwayRobbo » Wed Jul 18, 2018 8:30 am
Re: BARGAINS!
Postby Bigmet » Wed Jul 18, 2018 9:46 am
I have quite recently somewhat 'filled my boots' from that list, and a couple of their 'slightly damaged' s/h. Everything perfect, the 'slight damage' which their own very honest photographs showed proved to be a separate detail part from some other unknown model that had got wedged between bodyside and bogie and was released without any damage; and a loco body that is awkward to replace correctly on the mechanism, which I full well knew was not a problem.
Mike Parkes
Re: BARGAINS!
Postby Mike Parkes » Wed Jul 18, 2018 10:13 pm
RailwayRobbo wrote:Hattons Bachmann OO gauge sale.
http://www.hattons.co.uk/stocklist/1000 ... 0&pageid=1
Seems to be a Bachmann clearance going on with offers available at other retailers, so it may pay to look around. For example the Standard 3 tank in BR Green 31-980 is £88.99 at Kernow compared to £99 at Hattons.
Mike Parkes
Re: BARGAINS!
Postby Mike Parkes » Fri Aug 03, 2018 6:13 pm
10% off ebay puchases of £20 or more, max discount £50. Code PICKANY. Valid until 8pm tonight
mkrob
Re: BARGAINS!
Postby mkrob » Sat Aug 11, 2018 2:01 pm
Lidl have some good tools & diy accessories in this week and from next Thursday. The heat shrink tubing(£2.99) in stock this week could be use useful (for electrical insulation if you didn’t already know). They also have they crimping pliers/wire strippers(£7.99) + digital calliper(£9.99).
From Sunday19th ,various types of pliers are available for £2.49 each,plus other tools.
https://www.lidl.co.uk/en/Non-Food-Offe ... 747&week=1
https://www.lidl.co.uk/en/Non-Food-Offe ... leId=15145
https://www.lidl.co.uk/en/Non-Food-Offe ... leId=15154
https://www.lidl.co.uk/en/Non-Food-Offe ... leId=15156
https://www.lidl.co.uk/en/Non-Food-Offe ... 762&week=2
https://www.lidl.co.uk/en/Non-Food-Offe ... leId=15472
D605Eagle
Re: BARGAINS!
Postby D605Eagle » Fri Aug 17, 2018 3:09 pm
15% off ebay sales today only till 8pm enter code PIGGYBANK
mkrob
Re: BARGAINS!
Postby mkrob » Sat Aug 18, 2018 1:01 pm
Lidl are selling various pliers from tomorrow for £2.49 each or 2 for £4.
• Side Cutters
• Needle Nose Pliers
• Curved Needle Nose Pliers
• Long Nose Pliers
Re: BARGAINS!
Postby Emettman » Sat Sep 08, 2018 11:23 am
Anyone fancy a tram, with 9mm street track?
https://www.ebay.co.uk/itm/N-gauge-kato-bundle-including-tram-track-controller-11-107-chassis-6-bogies/273442460884?hash=item3faa70d4d4:g:-QQAAOSwy6lbjUTH
It's just asking for an OO plastic body on it. Or N, for that matter. Track's worth about £20.
And that controller!
(If anyone says "yes" I'll stay away, but otherwise I'll be keeping an eye on the price and if it stays low I might just try for a bargain.)
