Some NRM Xtrkcad threads condensed into one
Postby mumbles » Fri Mar 23, 2007 1:50 pm
To download, go to sillub page or
this is the link
http://sourceforge.net/project/showfile ... _id=151737
from the Wiki that was found and
Supplied by Rob Ironduke [as are most of the tips]
This is the Wiki for XtrkCAD, which also may be of some help
http://www.xtrkcad.org/Wikka/HomePage
To register, use this free registration key:
Name: Open Registration
Key: 248890010702
These two files add Hornby points and track sections to your XtrkCad tool bar in both OO and HO scale.
Instructions:
right click on these 2 links and choose "save target as" (for Microsift Internet Explorer) or "Save link As" (for Mozilla Firefox) and save it somewhere that you can find it e.g. the Desktop or "My Documents" (that's your My Documents not mine)
http://www.users.bigpond.net.au/robsstu ... rnbyHO.xtp
http://www.users.bigpond.net.au/robsstu ... rnbyOO.xtp
copy the files to \program files\xtrkcad\params
in XtrkCad go to Files, Parameter Files and browse for HornbyHO.xtp and HornbyOO.xtp
lots of Hornby things will appear on your tool bar.
How do you delete and join tracks?
To delete, move or rotate tracks:
click the Select button Image and click on the object you wish to select - it will go red.
Be careful, if you have selected anything before without UNselecting it they will also be effected by whatever you do now. To unselect everything first press the Esc key on your keyboard.
To move hold Shift + left mouse button and move the mouse.
To rotate hold Shift + right mouse button and move the mouse.
To delete press the Delete key on your keyboard.
If you like you can go to Options, Command and change the default command from describe Image which show information about things you click on, to select Image which selects.
To join two tracks click the join button Image then click on two unconnected ends of the tracks you want to join.
To set baseboard size
First go to Options menu, Preferences and set either English (imperial) or Metric
Go to Options menu, Layout, set room width and height to the dimensions or your baseboard and choose your scale
Can’t find 00 track?
No 00 track- select H0 instead
getting started
try laying a point first then click on the "modify or extend" button. now if you left click on any end of the point you can extend it straight, if you right click you can extend in a curve
How do I get the track view - at the moment it's just lines?
you can change the scale at which 2 rails show instead of just lines by going to Options menu, Display and changing the value of "Two rail scale". The default is 16. The 3 zoom buttons are in the top left corner. If you click the middle button the list of scales are there... note this is the scale of the screen not the scale that you are modelling.
I have down loaded the program but do not have any track all i can use is a flexi track. I do not have any points. Am i having a blonde moment or do i need to add or change something to the program?
In Options menu, click Layout and choose HO, not OO, there is no track for OO.
Also make sure that in File, Parameter Files you have Peco HO Scale Turnouts (if not, Browse for pecoho.xtp) and, if you've downloaded it from my website, Hornby Points and Track Sections
(HornbyHO.xtp
right click the above link and choose save target as,
copy the file into c:\program files\xtrkcad\params
In XtrkCad click Files, Parameter Files and Browse for the file)
Can I ask if anyone using Xtrkcad has noticed any strange behaviour in their Add/Remove Programs section of Windows XP?
After installing Xtrkcad I noticed a large black space within Add/Remove Programs where I would usually expect to see a list of applications. I've been told this behaviour happens when certain CAD software is installed. After un-installing Xtrkcad the 'black hole' went away.
This in no way affects the running of the program and is only really relevant to sad people like myself who notice these things.
I have been told that some CAD software includes a negative value in one of the registry entries and this is the cause of the 'zebra crossing' in the Add/Remove programs.
Uh, how do you post a screenshot of the layout?
you can also print to a bitmap file under File menu in XtrkCad. Choose a scale of 8. You have to convert the picture to a JPEG (and resize it usually) or it takes too long to upload.
How do I join a crossing to a turnout. I've laid the turnout but the crossing keeps using the wrong track to join.
How do you lay curved track? I want it to curve right but it will only curve left? If I turn it, it automatically snaps back when it reaches the laid track.
yep it's the same, Shift + left click changes the sticky end of the point or track section.
Hey, is there any way to set Xtrk to print the entire layout out, in full size, on A4? So that I can lay it on my baseboard and build on top of it?
Go to File and Print
Check in Setup that you are printing to the right printer and paper size (A4)
Set the Scale to 1
I usually choose to ignore margins so that sheets can butt right next to each other, otherwise you have to overlap the edges or cut them off.
Click Print Roadbed Outline if you are using roadbed (AMI or Foam underlay or woodlands or cork)
Choose Portrait or Landscape
At this point you'll notice that lots of rectangular boxes appear on the plan. These represent pages. Click to highlight the pages that you want to print (just do 3 or 4 as a test at first)
Click Print to print :^)
How can I find out how long all the track is, excluding points/crossings? So that I know how many yards of flexible track I need...
Highlight the track (or anything) that you want a list of (or go to Edit menu and choose select all to do the lot)
Go to File menu and choose Parts List
and finally
ok. XtrkCad beginners guide.... ummmmmm.
1.
If you're modelling OO, set your layout to HO: there's no track for OO in there. IE Peco Streamline track is there but it isn't called OO, same stuff though. If you're using Hornby track or peco Setrack include hornby3r.xtp in Parameter files (Ctrl-Alt-S)
2.
XtrkCad is really designed for Flexible track, its very difficult to construct a layout with set radii but not impossible. Just use flexitrack and Peco streamline points, they're better :^)
3.
For beginners set Easements to none (click the button that says "Easements" on the tool bar) Easements make for a better railway but the warning noise will drive you mad! You can change this by changing the default beep in Windows (Start/Control Panel/Sounds and Audio)
4.
Set your minimum track radius in Options-Preferences. Any curves tighter than this will show in Red, the default is about 60mm (or whatever the closest imperial measurement is) so if you're designing a layout using sectional track radii, the whole lot will be red! (Personally I wouldn't go under 55mm just because that was the radius of the circle I got with my first train set) You can also set "English" or "Metric" measurements here.
5.
Click options-layout and set the height and width of your table if its a plain oblong table or your room if the layout is "L" or "U" or "other" shaped. This is also where you set your scale, choose HO, N or Z (it also has other scales like P4 and On3)
6.
For an oval, start with 2 circles( the button with a circle and "95" in the middle). You can set the radius here (bottom of the window) or change it afterward with the "?" button. Then join the 2 circles.
7.
For a point to point layout, start with a straight or a point.
8.
Use the "modify or extend" button to run your track, left click extends a track (or a point) in a straight line, right click extends in a curve. Get the hang of this, it's my favourite part :^) everything makes sense once you master this.
9.
Use the parralel button if you run a double track. The default separation (in HO) is 2" (50mm) this fits with Peco streamline points exactly. You'll need to change it if you're using Hornby or Peco settrack points.
It will take a bit (or a lot) of practice before you get anything that you want to keep but it's worth it.
hope that helps
all credit to rob ironduke who has guided us all on the long lonely road through xtrckcadland, i just cut and paste!
michael
Honeywell
Postby Honeywell » Fri Mar 23, 2007 6:10 pm
Thanks Mumbles..
For now I've made it an announcement so it stays at the top of the forum list in this section.
It's also worth considering for the website articles section.. I shall point it out to Simon.
Postby mumbles » Fri Mar 23, 2007 6:19 pm
Honeywell wrote:Thanks Mumbles..
no worries, quiet moment at work today. would be fine as an article or just as a sticky for those that come to this section looking for help with layout design, might not get so lost like that?
michael
saslord
Site Admin
Postby saslord » Fri Mar 23, 2007 6:32 pm
Great Article.
It has inspired me to have another go at using Xtrkcad. This is what I needed the first time I used it.
This is a must have for the main site if you don’t mind me putting it on the main site mumbles?
Postby mumbles » Fri Mar 23, 2007 8:16 pm
saslord wrote:Great Article.
feel free, all i did was cut and paste from the threads about xtrkcad :D
most of the stuff was written by ironduke rob
michael
mortyfootball
Postby mortyfootball » Fri Mar 23, 2007 8:23 pm
Nice article there, shame I didn't use it the first time.
Shaun
Ironduke
Postby Ironduke » Fri Mar 23, 2007 8:54 pm
holy cow, Mumbles! :^)
I'm hoping to work up a collection of UK parametre files for XtrkCad.
So if anyone reading this has drawn their own custom structures based on UK kits please send them to me.
All you need to do is draw a small baseboard in xtrkcad that includes your custom buildings (hopefully with manufacturer and part number written nearby), email it to me and I can export them into these files (I think: I haven't actually tried it yet.)
Other scales welcome too :^)
Some Dapol stuff
Hornby for H0
Hornby for 00
Some Metcalfe stuf
Some Ratio Stuff
Some Superquick Stuff
Some Wills Stuff
To use :
1. Right click the item and choose "Save Target As" or "Save Link As"
2. Copy the files to C:\Program Files\XTrkCad\params on your windows PC
3. in XtrkCad go to the Files Menu, click Params, in the XtrkCad Parameter Files dialog click Browse, navigate to the parameter file you wish to add and click "Open"
Note that for ease of use Xtrkcad is used in HO for both HO and OO, this allows the use of HO scale items in OO scale and vice versa. If you use XtrkCad in OO scale there are no parameter files, except for trees and control panel items common to all scales, unless you edit the ones you have. Note: So far the Structure Parameter files contain only those kits which I've used on my layout and the part numbers are not accurate.
Honeywell
Postby Honeywell » Fri Mar 23, 2007 8:54 pm
mumbles wrote:all i did was cut and paste from the threads about xtrkcad :D
michael
Rob is excellent with XTrkCAD and has written a great deal.
Thank you very much to him for doing so and helping impart his knowledge.
Additionally in this particular case though thank you to Mumbles (what the feck is your real name anyway? Oh hang on.. Scrolling down it's Michael.. Anyway.. Thank you Michael for trawling the appropriate threads and compiling all the info into one place.
Knowledge is power, but unless you can actually find that knowledge then it's useless.
Get it (and other articles) online Simon :P
saslord
Site Admin
Postby saslord » Fri Mar 23, 2007 9:04 pm
Will do
Should I host the files on this site? I generally prefer to host files instead of linking to other sites so I have better control over the content and less chance of broken links.
I can also link to the Xtrkcad site for the program.
I will do an Xtrkcad page. Watch this space :D
Ironduke
Postby Ironduke » Fri Mar 23, 2007 9:28 pm
Saslord wrote:Should I host the files on this site?
That's a good idea.. Perhaps sillub will let you host the exe file too? Although I think they use winsite because they get some revenue from the advertising.
Raider
Postby Raider » Fri Mar 23, 2007 9:30 pm
As it's a free download, can they complain about someone else hosting it?
saslord
Site Admin
Postby saslord » Fri Mar 23, 2007 9:31 pm
They could. I will email them. :D
Ironduke
Postby Ironduke » Fri Mar 23, 2007 9:34 pm
I'm not sure.. it's still their intellectual property and they deserve something for all their hard work.. depends on how much they're making from winsite.
PTmodeller
Postby PTmodeller » Fri Mar 23, 2007 9:37 pm
very good, 'm printing as we speak!
Raider
Postby Raider » Fri Mar 23, 2007 9:42 pm
I guess it's freeware rather than open source - best to check really in case they get nasty
