What length would I need to rise 8".The run would include a 90 degree bend in third radius
An explanation of how this is worked out would be nice.thanks spo
Incline
- Roger (RJ)
Re: Incline
The steepest recommended gradient is 30 to 1 which means 1 unit of rise (height) for every 30 units of length.
In your case, to rise 8 inches you would need a minimum of 8 x 30 inches, which is 240 inches (20 feet) plus a bit more to allow for the extra drag of the curves.
Re: Incline
20 feet wow!
Have you thought about using a helix to get the track upto height Spo?
Re: Incline
Where are you going that needs 8" of clearance?
Re: Incline
And further questions such as what scale, steam or D&E traction, what size train loads are proposed, are traction tyres or magnetic assistance acceptable?
