N Gauge Plan
2.0M x 0.81M
Having finally gotten around to designing a layout over furlough I thought i would post it here for positive comment / critique
The intent is to create 2 continuous main line loops and an independent branch line loop. Also i would like to " stock " the board with alternative carriages and wagons which end i have added some carriage sidings and albeit a very small goods yard. On the same premise a have created a turntable and round house to create engine diversity.
Operationally im not looking to achieve anything other than a working model without basis of actual running practices in other words a model railway .
As my stock is some 30 year old minitrix and farish I have opted for a minimum radii of 298mm ( PECO SETRATCK 2ND RAD ) and will have to work out analogue wiring logisitcs ha ha .
The layout has been designed in Solidworks using full scale points and crossings etc as i got fed up of trying to use anyrail or scarm.
I look forward to any comments on my FIRST post
Jules
n gauge layout design
Re: n gauge layout design
Hello. Welcome. I have seen your plans somewhere before? Hehe. It is a good plan and carefully worked out too.
Hi Mountain didnt know which forum to post to hence i posted in both being a newbie ha ha
I did want to be Mountain Goat when I joined this forum as well but it did not let me.
