Michaelreedy71 wrote:Whats the easy way to make a helix I have a sheet of 6mm and 9mm mdf sheeting and is it easy to build
Back a few steps for some significant questions.
What scale is this for?
What does the helix have to do in terms of height change, and within what maximum available dimensions?
What combination of traction and quantity of rolling stock will make up the trains to operate on the helix?
As for ease of building, it has to be planned and the parts carefully cut and assembled, it's not a 'thrown it together' build. MDF in my opinion will be best restricted to the smallest modelling gauges, N or OO9 as a maximum. I wouldn't consider it for HO or OO and larger, plywood is stiffer and will be more structurally stable which is necessary if the helix is to perform well.
Finally. A helix, whether 'classically arranged' on a circular plan, or as 'Mountain' suggests distributed around an oval or some other shape. is best thought of as an 'expander' for a model railway already in a generous space relative to the scale.
