Santa Special
kebang
Santa Special
Postby kebang » Sat Nov 24, 2018 12:25 pm
Trying to make a slight improvement on the Hornby 'Santa Special' track (which is a 1st rad oval) to make it more interesting as it circles the Christmas Tree. Is a loco & a couple trucks going to be able to cope with the gradients shown?
45655
Re: Santa Special
Postby 45655 » Fri Dec 07, 2018 3:43 am
It depends on the stock, the only way really to know is to set it up and see if it works.
kebang
Re: Santa Special
Postby kebang » Fri Dec 07, 2018 9:48 am
I was thinking that I need to 'suck it & see'. Unfortunately its not been delivered yet! Packed & dispatched by Hattons on 16th. November but no sign of it yet :(
I'm sure its not Hattons fault, Once the package arrives in Manila It takes at least another week for it to make its way to Bohol, plenty of chances for it to get mislaid by Philpost.......
I think this the reason a lot of suppliers won't post to the Philippines.
Re: Santa Special
Postby Mountain » Sat Dec 08, 2018 8:58 pm
00 gauge or 0-16.5?
kebang
Re: Santa Special
Postby kebang » Mon Dec 10, 2018 12:28 pm
Its the OO gauge Hornby 'Santa Express'. Purchased for running around the base of the Christmas Tree. The good news is it has finally arrived here in the Philippines. Collected it from the post office this afternoon.
Tomorrow I'll see if it can manage the 'roller coaster' I've designed for it!
Re: Santa Special
Postby Mountain » Mon Dec 10, 2018 7:07 pm
I have a little set though it wasn't thw Christmas set. I was using it to test trains but I have noticed the wire casing has come away near the transformer itself, so those who own Hornby controllers (Or actually any similar transformer) do a check that the wire casing has not come away bearing the internal wire. It is a good job I've noticed before the bare wires touched. I may be able to do something with it. If not, I have another little controller. I only used it as a convenient way to test trains.
It is a lovely plan Kebang. Being 00 gauge and just having short trains, I don't see an issue with the gradients. If you want to run longer trains then it won't work, but for just a few wagons it should work OK.
Montfort2
Re: Santa Special
Postby Montfort2 » Sun Dec 22, 2019 8:52 am
Maybe it's the right time for a little update... :D
Re: Santa Special
Postby Bufferstop » Sun Dec 22, 2019 11:15 am
Hi Mountain, you are right to highlight the problem of ancient mains leads. Any one thinking of buying one of the "good old last forever" H&M power units should be well aware that any that are advertised will by now have a mains lead well beyond life expired. It's easy enough to change the mains lead but you'll find the case is riveted closed. Only drill out those rivets if:-
- you are never going to sell it on and you feel competent to change the lead, or -
- you are and can show that you are qualified to repair mains powered equipment and the power unit will be PAT tested before being sold.
We don't want any accidents especially in this season of festivities.
Montfort2
Re: Santa Special
Postby Montfort2 » Sun Dec 22, 2019 1:40 pm
:oops: :oops: :oops:
Re: Santa Special
Postby Mountain » Sun Dec 22, 2019 2:32 pm
How is the idea coming along? It does not just have to be a Christmas idea. It can be a whole year idea.
The leads exposing wires I mentioned earlier are from the modern Hornby plug in transformers. The grommet parts are not flexible enough to flex with the wires and therefore stress the wires at the edge of the grommet if that makes sense?
