Layout feedback please
Moorway South
Postby Moorway South » Wed Nov 07, 2012 1:45 pm
I have started playing around with ideas for the OO gauge layout in an 8'x8' room (probably an inch or two more) to go around the room. Taking onboard comments made previously, I have the north and east sides at 2' wide, the west and south at 1' wide. There would be a lifting section at the south west for the door which opens externally.
As I say, I am still just having ideas at the moment - I would like an express route to allow the HST / InterCity service to run continuously, with an inner line for DMU, local goods, etc.
Attached is an initial idea - though the detail doesn't match up, I'm just trying to get an overall impression.
Is there any way of avoiding the rounded off square look or making the general shape more interesting?
Any thoughts and ideas gratefully received.
Simon
craw607
Re: Layout feedback please
Postby craw607 » Wed Nov 07, 2012 1:56 pm
Interesting looking layout a few thoughts on looking couldyou connect
turntable to passing loop on left side to allow train to run anti-clockwise.
I know you could run into station then change loco around to go in this direction.
John
AlanBrady
Postby AlanBrady » Fri Nov 09, 2012 8:59 pm
Probably the only way to avoid the 'rounded square' look is to use flextrack. You're not limited then. You can go wherever you want to ... sort of. The right could be a sweeping station. The bottom and left could be through countryside or mountains.
Hope that helps.
Alan.
Users browsing this forum: Google [Bot] and 2 guests
