Moving my 00 layout outside in the garden
Discussion on OO, and O gauge garden model railway design and construction. (scenery, track laying, electronics)
Pannier09
Postby Pannier09 » Tue Apr 05, 2011 10:23 am
Hello everyone,
I've been thinking recently about moving my 00 layout from inside the house to outside in the garden and I wanted know:
  • How do I do it?
  • Will my Hornby tracks, Level Crossings, locos and platforms be safe outside?
  • How do I protect my tracks from nature i.e rain and animals?
  • What do I need?
Many thanks
thomas the plank engine
Re: Moving my 00 layout outside in the garden
Postby thomas the plank engine » Wed Apr 06, 2011 9:20 am
Pannier09,
I can only suggest that you browse through the garden railways that are already on here, and with some luck hopefully should be able to anser most of your questions.
This time however I am not going to make a list of who's, as last time I did that I missed a few out and got my knuckles rapped. :D
Warning
Sun and plastic are not a good combination, as the plastic will distort
Ian
Pannier09
Postby Pannier09 » Wed Apr 06, 2011 9:43 am
thomas the plank engine wrote:Pannier09,
Warning
Ian
Thanks thomas the plank engine
So that's a no on the level crossing.
0121modeller
Postby 0121modeller » Wed Apr 06, 2011 11:42 am
I dont have a garden railway, but I've listed a few commonsense points.
Dont ever be tempted to leave any of your locomotives & rolling stock outside overnight or when nobody's at home, keep loco's, rolling stock & the transformer controller or DCC control box etc safely stored indoors.
240v extention leads must also be kept indoors OR a permanant 240v power supply cable & its 3 pin sockets must be adequetly installed with exterior grade armoured cable in trunking & buried as to protect from the weather & possible accidents chopping cable with the garden spade etc.
To deter cats from damaging scenery , I've heard say that if you leave a few pieces of orange peel lying around , cats do not like the scent of this & will avoid.
Possibly install some cctv camera's with infered & motion detection / PIR activating a recording device of some format VHS, DVDR , HDD etc ,
How large is the layout ? I assume the layout is on trestle mounted baseboards , what are the baseboard frames & baseboard top / trackbed made out of ?
You'll need to weather proof all wood & plywood. I use Saddolin stain to protect the timber of my shed & back gate , but if not Sadolin, then use firstly a paint thats solvent / oil-based primer paint, then when dry, apply a solvent / oil-based topcoat, oil-based takes longer to dry but is kinder to wood grains & is more water repellant & it gives screws bolts & nails good protection, unlike water based paints.
Ideally, you'll need some sort of overall cover, a gazebo or similar sort of thing as to cover most if not all of the layout from rain, but something more robust & stable to protect from high winds, a wooden lean-to maybe ? A 7ft x 3ft x 6ft high lean-too made from 4"x2" tanalized CLS timber open framed with sloping roof , dessign & building this yourself works out to be stronger more suitable & cheaper than a 6ft x 4ft shed, I built a smaller lean-too for storing my garden furniture etc.
It all depends what size your layout is.
Dave.
Pannier09
Postby Pannier09 » Wed Apr 06, 2011 12:22 pm
0121modeller wrote:I dont have a garden railway, but I've listed a few commonsense points.
Dave.
Thanks for the advice,
The size of the layout is 6ft x 4ft and currently not on a baseboard due to the lack of size.
Return to “Garden Railways”
