The one improvement Hornby could have usefully incorporated is to fit a Bachmann style screw locked slide adjustment to the loco to tender drawbar; so I had to make a new shorter drawbar and file a little off the intermediate buffer mouldings on the tender drag box. Now the fall plate and cab doors close the gaps as they should, and the loco will still sail around a 24" radius curve which is smaller than anything on its owner's layout; where layout curves permit closing up engine and tender to scale separation just ices the cake in appearance of any tender loco.
Once test running was complete, I gave it a traction test yesterday afternoon, and it is good for more than 60 wagons or 15 coaches, more than adequate for the type, which had a 5P6F rating. A very complete model of a medium mixed traffic type in short.
(Although not applicable in this case, Hornby knew it was practically perfect in every way, so on the first production run had the attachment of the tender side frame mouldings performed near cement free, so that they often fall off, just to give us something to grumble about. A little ABS effective solvent cement swiftly and invisibly fixes this should it arise (butanone, plastic magic. etc..).
