Difference between Mallards..
Steamingon
Postby Steamingon » Sat Jan 30, 2021 10:37 am
Other thank the model & colour, are there any major differences between these two Mallards. Hornby R3395TTS LNER & Hornby R3737 BR.
R3395 has dimentions of 10.2 x 6.1 x 36 cm; 550 Grams & R3737 BR has 36.2 x 11.2 x 5.8 cm; 620 Grams. Both are 00 gauge, why is the one bigger? Thanks for any help.
Re: Difference between Mallards..
Postby Bufferstop » Sat Jan 30, 2021 10:58 am
The difference in weight is almost certainly due to the presence of the sound system in the TTS model, the difference in the other dimensions are small enough to be down to the way in which they were measured. Any attempt to measure on the surface of Mallards curves is going to increase the apparent size. The only truly repeatable measurement would be using a large pair of callipers to measure, overall length with tender gap closed up, height from rail level to highest point and width over the widest point. Doing it with a tape would be extremely variable.
Steamingon
Postby Steamingon » Sat Jan 30, 2021 11:17 am
Thanks, but the sound one is the lighter (weight) loco.
Do they use the same motor? I can't quite see why the non sound one is more expensive.
Postby Bigmet » Sat Jan 30, 2021 11:42 am
The linear dimensions are for the packaging, and bear only some relation to the model inside, the box just has to be big enough for it fit.
The difference between the two models, reflected in the price:
The Railroad model uses older tooling, less accurate in many respects, lacking detail to keep the price low (no cab window glazing for example); no idea of the motor now used, not had one to look at for a good many years.
The main range model is from the tooling introduced in 2004, which is overall the best rendition of the difficult body shape yet seen in RTR OO, also provides for the three major tender variations, carries pretty much all the exterior detail practical in RTR OO; good mechanism with Hornby's 5 pole skew wound black can motor.
Postby End2end » Sat Jan 30, 2021 12:15 pm
Bachmann also make A4's. You might want to take a look at their range too. :idea:
Steamingon
Postby Steamingon » Sat Jan 30, 2021 3:26 pm
Thanks Bigmet.
Thanks End2end. I will take a look.
Postby Bufferstop » Sat Jan 30, 2021 7:29 pm
Steamingon wrote:Thanks, but the sound one is the lighter (weight) loco.
In which case they've cut away a chunk of the chassis to accommodate the TTS decoder.
Postby Mountain » Sun Jan 31, 2021 2:51 pm
Didn't Hornby refresh their model at some stage? Their class A4 origionated in 1979 and was tender drive with a Ringfield motor.
I would imagine the railroad ones with TTS are most likely to have come from this design.
I seem to remember Hornby making a more modern revamped model or am I mistaken?
Bachmann came out with a lovely A4 but it was a pain to convert to DCC having a split chassis and no room for a decoder, but I would imagine they would have altered the design since then.
Doesn't Dapol now make a class A4?
Of course, there are also the lovely Hornby Dublo and Wrenn examples.
All the above mentioned are in 00 gauge.
Graham Farish did an A4 in N gauge but they seemed prone to wobble. I do not know if they still make them since Bachmann took them over.
stuartp
Postby stuartp » Sun Jan 31, 2021 4:14 pm
Hornby's A4 was retooled on a loco-drive chassis around 2004. The Railroad version (and 'Spencer' from the TTTE range) are a hybrid of either the old body or a simplified verson of the new one, the old ex-Ringfield tender, and the loco drive chassis from the retool with slightly more robust valvegear.
The Bachmann A4 is the ex-Trix model and i don't believe it has ever been retooled. The Dapol model has a diecast body and is nearly three times the price of the main range Hornby one.
Postby Bigmet » Mon Feb 01, 2021 9:37 am
End2end wrote:Bachmann also make A4's. You might want to take a look at their range too...
Current model has the same body mouldings as Bachmann's earlier split chassis versions.. To make sure of getting the current production, it should have a DCC decoder socket. It does have a better rendition of the chassis than the Hornby, such that I have occasionally thought of trying this mechanism in the current Hornby body.
Mountain wrote:...Doesn't Dapol now make a class A4?...
That's a good question. Their 'Black Label' A4 production appears to have been a limited edition, and not a word since about any further releases.
I am waiting to see if Hornby move to add a metal bodied A4 to their range...
CasperGriswoldBacon
Postby CasperGriswoldBacon » Thu Feb 11, 2021 10:36 am
stuartp wrote:Hornby's A4 was retooled on a loco-drive chassis around 2004. The Railroad version (and 'Spencer' from the TTTE range) are a hybrid of either the old body or a simplified verson of the new one, the old ex-Ringfield tender, and the loco drive chassis from the retool with slightly more robust valvegear.
Really?! As the proud owner of an old trix A4 I never knew that. Must be near the oldest if not the oldest tooling still going I would have thought.
Postby Bigmet » Thu Feb 11, 2021 11:15 am
CasperGriswoldBacon wrote:
stuartp wrote:HThe Bachmann A4 is the ex-Trix model and i don't believe it has ever been retooled. ...
The Trix LNER pacifics were the class act of their day in RTR OO for appearance, and a good tooling remains one, if it is carefully maintained. The Trix A4 body shell even gives some impression of the roll under of the valance following the cylinder underside, a feature that Hornby are just introducing now. (Had the Trix A3 body tooling survived in usable condition, I should think Bachmann might have had that in the range as well...)
CasperGriswoldBacon
Postby CasperGriswoldBacon » Thu Feb 11, 2021 4:50 pm
Oh I've always liked the Trix's. In fact I nearly bought an A2 a while back on impulse. Just never knew the A4 was accurate enough to still be acceptable. 50 odd years later.
