The new 'smokey joe 'R3822
mjb1961
Postby mjb1961 » Mon Jul 13, 2020 9:01 pm
Hi ,,I've ordered this new smokey joe ,still waiting for it to arrive,what I would like to know is ,could it be converted to dcc ,I'm sure it isn't dcc ready and I'm also sure the chassis and motor etc are the same as it was years ago ,I know that space might be a problem but still I would like to know if it can be done ,has anyone else converted this loco ,look forward to any advice,thankyou in advance ,,mjb
Alexander Court
Re: The new 'smokey joe 'R3822
Postby Alexander Court » Mon Jul 13, 2020 9:26 pm
He can be wired to DCC but will involve soldering, Hornby have a guide if you follow this link:
https://www.hornby.com/uk-en/hornby-dcc ... stallation
Hope that helps,
Alex
Postby Bigmet » Mon Jul 13, 2020 9:36 pm
If it is the same loco as previous Smokey Joes/Caley pugs etc there's room above the worm end of the motor and more can be made by sawing off a little from the front upstand of the casting, and the wiring is readily accessible.
mjb1961
Postby mjb1961 » Mon Jul 13, 2020 9:54 pm
Alexander Court wrote:He can be wired to DCC but will involve soldering, Hornby have a guide if you follow this link:
Hope that helps,
Alex
That's great Alexander ..thanks
mjb1961
Postby mjb1961 » Mon Jul 13, 2020 9:56 pm
Bigmet wrote:If it is the same loco as previous Smokey Joes/Caley pugs etc there's room above the worm end of the motor and more can be made by sawing off a little from the front upstand of the casting, and the wiring is readily accessible.
And thankyou to you bigmet for the extra info,,
Postby Bigmet » Tue Jul 14, 2020 9:12 am
It's a good while ago now, but I wired a Zimo MX34 on one of these mechanisms for a friend, who was using it to power an 0-4-0T body he was building. (This was the old version with Scalextric performance, and at the time that Zimo decoder was three times the price of the mechanism, which he had bought s/h for under a tenner.) But it fully did the job, the finished loco ran as smoothly and slowly as a Bachmann Jinty with a Lenz decoder; Zimo's range of CV adjustments making it into a 'good dog', Barbara Woodhouse style.
Postby Mountain » Tue Jul 14, 2020 12:36 pm
I used a little N gauge decoder and put it in the back of the chassis under where the loco crew would stand.
RAF96
Postby RAF96 » Wed Jul 15, 2020 4:28 pm
Plenty of room to fit an 8-pin socket as well.
RAF Halton Brat - 96th Entry
β-tester
