Hornby R602 Power clip
Re: Hornby R602 Power clip
Postby End2end » Wed Feb 08, 2017 3:47 pm
End2end wrote:Solder your wire to the outside of the track instead. :idea: :)
Kerluk wrote:First soldering test. Not really my best shot, but it's a start And I saved a lot of money and time
Kudos! :mrgreen:
Endend
DonnyRailMan
Postby DonnyRailMan » Wed Feb 08, 2017 3:53 pm
See that looks a lot better than the power clip.
alex3410
Postby alex3410 » Wed Feb 08, 2017 3:58 pm
my soldering its not fantastic so i normally opt for pre soldered fish plates.
either way they will be far easier to hide and look much better then the power clip!
Kerluk
Postby Kerluk » Wed Feb 08, 2017 4:30 pm
DonnyRailMan wrote:See that looks a lot better than the power clip.
You're absolutely right !
Roger (RJ)
Postby Roger (RJ) » Wed Feb 08, 2017 5:21 pm
Nice job for a first go.
Would look much better if you solder to the underside of the rails. You may have to cut some plastic away to make a clear space between the sleepers. If you do each rail between different pairs of sleepers the sleeper spacing can be maintained stopping it from closing up. On flexi track there are staggered breaks in the plastic base which are ideal
Kerluk
Postby Kerluk » Wed Feb 08, 2017 5:30 pm
Thanks for the kind comments and for the advices.
