Hornby MK3 bogies
InterCity125
Hornby MK3 bogies
Postby InterCity125 » Sat Dec 07, 2013 9:43 am
Does anybody know where I can source spare MK3 bogies? (Not the old type) thanks for any help you can give me.
http://modelrailpenzance.wordpress.com/
http://www.newrailwaymodellers.co.uk/Forums/viewtopic.php?t=43236
Favourite diesel loco: 47 406 'Rail Riders' (Class 47)/ 9006 'The Fife and Forfare Yeomanry' (Deltic)
Favourite steam loco: 3705 (Pannier)
InterCity125
Hornby MK3 bogies
Postby InterCity125 » Sat Dec 07, 2013 9:49 am
Also disc brake inserts for Hornby 12mm disc wheels.
martin_l_jones
Re: Hornby MK3 bogies
Postby martin_l_jones » Sat Dec 07, 2013 6:47 pm
No more fotopic, now onto flickr...
Just started to load up my photos and video, see my layout and the real things at..
http://www.youtube.com/user/mljones21
http://www.flickr.com/photos/16645820@N06/6157779077/
martin_l_jones
Postby martin_l_jones » Sat Dec 07, 2013 6:49 pm
Ranger
Postby Ranger » Mon Dec 16, 2013 1:12 pm
If you're after bogies for the scale length Mk3's, I don't think thay're available as a spare. (I'm after some myself). I've only been able to find bogies for the old 'shorties'.
Hornby themselves have no idea if they're available as spares either! :shock: and just send you away.
System: Lenz LZV100 (v3.6)
Control: Lenz LH90 & Lenz LH100 Throttles, Lenz LAN-USB PC Interface (23151).
Only the insane have strength enough to prosper,
Only those that prosper truly judge what is sane.
InterCity125
Postby InterCity125 » Wed Dec 18, 2013 6:01 pm
Yes, the long ones, not the shorties. I wonder if they could be converted?
Leader
Postby Leader » Fri Dec 20, 2013 5:06 pm
Hornby scale length MK 3 complete bogies (ex Lima) are available as spares. Part numbers are X9185 and X9186. These are grey bogie frames , so you will have to paint them.
Leader
Postby Leader » Fri Dec 20, 2013 5:44 pm
InterCity125 wrote:Also disc brake inserts for Hornby 12mm disc wheels.
Wheels with disc brakes inserts fitted are available . These are used on the Super detail HST non motorised car and are available as bogie wheel sets (two axles). Their part number is X9861. Service sheet HSS332 refers. I also think that the Pendolino non powered car wheels are fitted with disc brake inserts. They are a smaller diameter wheel. These are part number X9704 (four axles) Service sheet HSS302 refers
rosenblad
Postby rosenblad » Fri Dec 20, 2013 9:07 pm
Bachmann disc brake wheels 36-017 are a perfect fit for the Hornby Mk3 bogies and they look superb!
Carpe Diem!
InterCity125
Postby InterCity125 » Sat Dec 28, 2013 5:01 pm
Leader wrote:Hornby scale length MK 3 complete bogies (ex Lima) are available as spares. Part numbers are X9185 and X9186. These are grey bogie frames , so you will have to paint them.
That was very helpful Leader, I would never have known that if you hadn't said! I have come across Colin Craig 4mm finescale disc brakes, and I am going to use those probably.
