Complete Lima stock list
tstageman
Postby tstageman » Thu Sep 02, 2010 5:19 pm
Does anyone know where I could find a complete list of all of Lima's products, including each and every livery? This is when the models were produced under Lima and not the newer updated Hornby versions.
Many Thanks
Tom
thomas the plank engine
Re: Complete Lima stock list
Postby thomas the plank engine » Fri Sep 03, 2010 5:22 pm
One source of information could be kleened from the following book
Ramsay's British Model Trains Catalogue
ailable via any good WH Smith's newsagents
Ian
martin_l_jones
Postby martin_l_jones » Sat Sep 04, 2010 12:08 pm
There used to be a Lima Collectors Club, I was a member and they had a really good catalogue listed products in catologue number and also class number.
I have it in the loft somewhere !!
Is there anything specific you are trying to find out.
Have a search through Yahoo groups..
I found this..
http://mmiwakoh.de/Eigene%20Webs/lima-m ... 1%20en.htm
Also
No more fotopic, now onto flickr...
Just started to load up my photos and video, see my layout and the real things at..
http://www.youtube.com/user/mljones21
http://www.flickr.com/photos/16645820@N06/6157779077/
tstageman
Postby tstageman » Mon Sep 06, 2010 11:07 am
Thanks for your replies. I just wanted to find a complete list including every livery they produced, but apart from that nothing else specific no.
Tom
martin_l_jones
Postby martin_l_jones » Mon Sep 06, 2010 9:05 pm
To be honest there was not a lot they didn't do, lots of limited editions brought unusual liveries.
All the mainline liveries in terms of locos and passenger stock was produced.
The catalogue was massive.
47FAN
Postby 47FAN » Tue Sep 14, 2010 4:37 pm
Yes, that is right. Lima did bring out limited editions. A friend of mine has a Lima Porterbrook liveried Deltic. The purple colour surprisingly suits the lines of the Deltic very well. Not sure what year this comes from though.
K9-70
Postby K9-70 » Tue Sep 14, 2010 9:11 pm
47FAN wrote:Hi
L205260 #9016 "The Gordon Hughlander"
Porterbrook Purple Ltd Edn 1200 released in 2000
K9-70
The Rides the "REASON" the "DESTINATION" is only an "EXCUSE" :-).
martin_l_jones
Postby martin_l_jones » Sun Sep 19, 2010 11:17 pm
K9-70 wrote:
47FAN wrote:Hi
K9-70
They did the Class 47's in porterbrook as well.
Lots of Lima here...
http://www.modelfair.com/acatalog/Lima_Class_47.html
47FAN
Postby 47FAN » Tue Nov 23, 2010 4:45 pm
There seems to be a lot of brand new boxed Lima models out there. Recently been to a fair whereby a stall holder bought a large batch of brand new condition boxed Lima models from a collector that never ran them. I bought a green Class 47, but a common problem seems to be the motor bogie, it does not turn very well. when running on the layout, the motor bogie stays in the straight position when on the curves, thus derailing. Unless I shave the plastic I find this a tricky one to solve. Ay ideas anyone?
0121modeller
Postby 0121modeller » Tue Nov 23, 2010 5:44 pm
47FAN wrote:but a common problem seems to be the motor bogie, it does not turn very well. when running on the layout, the motor bogie stays in the straight position when on the curves, thus derailing. Unless I shave the plastic I find this a tricky one to solve. Ay ideas anyone?
Had that problem myself with a lima 47, I solved by disconnecting motor bogie & used a half round 1 inch width file to remove 0.5mm from chassis , or equally as effective would be to file both front & rear of the bogie using a smaller quarter inch wide flat file.
Dave.
47FAN
Postby 47FAN » Wed Nov 24, 2010 4:11 pm
Thanks for that. It seemed this was a widespread problem Lima had with 47s. Surprised that so many left the factory in this condition. My friend has got a few of these and nearly all have this motor bogie fault.
martin_l_jones
Postby martin_l_jones » Sat Nov 27, 2010 9:57 am
It doesn't take a lot to allow the bogie to swing freely, if you move the bogie one way to its furthest position use a stanley blade or similar to scrApe across the inside face of the curved slot.
Don't remove too much they soon free up.
