I've taken some pictures if anybody here can help.
The wiring.
The bulbs, wrapped in what looks like a heatsink jacket
The loco's motor
Thanks.
David.
steviesparx wrote:Do mean add new lights, or reinstate the original headcode lighting ?
K9-70 wrote:The early versions of the blue and green Class 25 fitted with the headcode box had lights fitted to ilumate the headcode box.
The later version of the blue Class 25 with the two white discs didn't have the lights fitted.
K9-70
6C wrote:K9-70 wrote:The early versions of the blue and green Class 25 fitted with the headcode box had lights fitted to ilumate the headcode box.
K9-70
I have a green 25 'D7571' which had no lighting .....
steviesparx wrote:Yes, but none had headlights fitted, just the headcode box, with or without the headcode or two dot blank code...
I think the OP wants to add marker lights, similar to the Bachmann 25 - He has all the original parts for reinstating the existing headcode box lighting in the pictures above...
K9-70 wrote:6C wrote:K9-70 wrote:The early versions of the blue and green Class 25 fitted with the headcode box had lights fitted to ilumate the headcode box.
K9-70
Br Green, both models came with directional lights that operated in the direction of travel.
1977/79 R072 #D7596
1980/83 R327 #D7571
This model was not produced between 1984 & 87.
Br Blue, both models came with directional lights that operated in the direction of travel, except for the 1984 model.
1977/79 R068 #25 247
1980/83 R326 #25 241
1984 R326 #25 241 No lights fitted.
When both models where reintroduced again in 1987, neither of the Green/Blue models had directional lights fitted.
It is possible that the lights on your model have been removed at sometime in the past.
K9-70
6C wrote:
Eeek! I have d7571 in the green body - but marked R068...
