Origional Hornby Class 58.
Re: Origional Hornby Class 58.
Postby Bigmet » Tue Jan 05, 2010 8:53 am
Neat conversion. Are you going to convert the original motor bogie to take the (disc drive?) motor used in the converted bogie?
glegalee
Postby glegalee » Tue Jan 05, 2010 8:08 pm
Yeah, I expect that I'll convert the second bogie, now that I know that it can be done quite easily on a milling machine and after I have run some tests, I have many can motors that I have been collecting from PC CDROM drives. I tested the motor after I pressed the Brass gear onto the shaft and found that I had damaged the fitted motor, I'll replace it and try again. Then I'll move on to the next one.
On another note, I am quite looking forward to the arival of my new edition the my fleet, I bought a Hornby Class 66 from a fellow NRM member, I have wanted one of these for ages. It's 66702 in GBRf Livery. Should arrive in a few days.
Cheers.
Visit my layout CHOLMONDELEY PARK
glegalee
Postby glegalee » Sat Jan 16, 2010 11:09 pm
Well, It's been a week or so now since my last post on this subject, I finally got round to finishing this mod , as promised here is a video of it running with its new motor. Unfortunately I had to use parts from the old motor so I couldn't do a comparison video of old vs new.
Here's the video
I am very pleased with the performance of the new motor, as you can see the new one can easily pull 6 coaches, I've not tried any more than that. Where as the original motor could barely pull 2.
Cheers G.
dubdee1000
Postby dubdee1000 » Sat Jan 16, 2010 11:37 pm
Interesting article. I've got the same 58 with the same lifeless performance and like you, a touch of sentimentality for it. I noticed in your video that you've got a Pacer. Is that next for the power boost?!? :wink:
glegalee
Postby glegalee » Sun Jan 17, 2010 7:45 pm
No, the pacer runs fine, no need for me to modify it. I am on the other hand looking for other engines to create mods for.
Thanks for reading G.
