New Railway Modellers, the model railway website dedicated to beginners and those returning to the hobby, with basic and advanced model railway information on all aspects of the model railway Hobby.
Entire Web NRM
Home
Introduction
What train set to buy
Cost
Basic Tools
Base Board
Railway Track
Track Conversion
Building a Layout
Layout Designs
Members Layouts
Electronics
Digital Control (DCC)
Electronic Projects
Scenery
Plastic Kits
Rolling Stock
Maintenance
Service Sheets
Harry Potter
Thomas Tank Engine
7mm Narrow Gauge
Railway Software
Downloads
Photo Gallery
FAQ
Forums
Classified Ads
Railway Dictionary
Competitions
Links / Sponsors
Terms & Conditions
Contacts
 Scenery
Airbrushing
Ballast
Bridges
Buildings
Building Lighting
Grass
Hills
Inclines
Paint Conversion
Rock Faces
Hornby Skaledale
Railway Stations
Trees
Tarmac
Tunnels
Viaduct
Water
Finishing Touches
Electronic Projects
Railway Crossing
Building A Signal
Street Lights
Rolling Stock
Bachmann Wagons
Hornby Locomotives
Hornby Carriages
Hornby Wagons
Lima Locomotives
Lima Wagons
Loco Modification
Wagon Modification
Hornby Range Lists
Hornby Range 2006
Hornby Range 2007
Hornby Range 2008
Hornby Range 2009
Hornby Range 2010
Hornby Range 2011
Lima Model Railway Locomotive Reviews -  Class 156 Super Sprinter DMU
Author "Metrocamel" (forum member)
Worth Buying - This is an average model. The model has limitations and does not have a full range of mechanical or detailing features. For a railway model to be rated as "Worth Buying" a model must score between 4 and 7. Lima Class 156 Super Sprinter DMU Rating 7/10
The Lima Class 156 is truly an excellent model. By modern standards it could do with improvements however. Detail to the under frames is minimal and the exhausts by the joining ends of the cars are left black.
End detail is very good with lights fitted at glass or plastic in small drilled holes to give an effect far better than the painted on types seen on Hornby Class 142 Pacers. One car is powered with the motor visible inside but not too much. The windows are nice and flush too and the roof grooved like the real thing.
156443 is pictured alongside a Bachmann 158.
In trials the model runs very well and makes a very realistic engine sound which may or may not have been intended. It takes to most speeds well and slow speed control is good. A better motor than the old type ringfield would make the model more reliable.
Destination boards are stickers which are one of the few bad points on these models. Mine was bought from Ebay and so they were already stuck on. Replacements should be easy to make if you wished.
Gradient climbing has not been tested but the model has little in way of heavy weight or weight difference between the cars and so should run up and down slopes well.
The model could do with a few things to make it perfect for your chosen period or location. A detailing kit is available from Hurst Models which replaces the under frames with more detailed ones and adds other details such as debris collectors. Snowploughs are also available which are fitted to Scottish Class 156 units. Lights would improve the model greatly and Express models produce kits for both DCC and DC including an advance day and night digital set.
The Hurst Models kit as it looks applied to a Class 156 without paint applied to it.
Overall the Class 156 is a must for modern image and even though it is out of production it looks like Hornby will revive this amazing DMU.
At a Glance
Good points
  • Reliable
  • Variety of Liveries
  • Variety of upgrades
Bad points
  • Poor under frame detail
  • dated motor
Resources
Name - Class 156 DMU.
Manufacturer - Lima
Liveries produced - Provincial 156443, 454, 470, 480, 481 and 465 (last with Scotrail logos). Regional Railways 156402 and 420 (last with Green stripe). Central Trains 156407. Strathclyde PTE 156433. Strathclyde 156501, 502, 512 and 513. Scotrail 156447. Northern Spirit 156490.
Class History - http://members.madasafish.com/~dysgraphyk/156/class156_origins.htm
Notes - 156470 is a single car while all others are two car sets. Hornby plans to re introduce three Class 156 models, these are Central Trains 156401, Strathclyde PTE 156430 and Northern Rail 156425.
Also see Hornby Class 155 and Bachmann Class 150/1/2 which is due this year.
Available from - This model is out of production but is often sold on Ebay and should be available from some outlets with remaining stock and other such outlets.
Upgrading the model - Hurst Models for a detailing kit and snowploughs. http://www.hurstmodels.com/4/hm_4mm.htm
Express models for lighting kits. http://www.expressmodels.co.uk/
[back to the top]
Lima Diesel Locomotive Review List
Model Railway Review - Lima Class 59 - EWS Model Railway Review - Lima Class 73 - Intercity
Model Railway Review - Lima Class 156 2 Car DMU Model Railway Review - Lima Railcar - GWR
Bachmann Locomotives
Bachmann Coaches
Bachmann Wagon
Hornby Locomotives
Hornby Coaches
Hornby Wagons
Heljan Locomotives
Lima Locomotives
Lima Wagons
Locomotive Modification
Wagon Modification
New Modellers Shop - A Model Railway Shop - Stocking model railway wagons, coaches, carriages, electric diesel and steam locomotives, power and control equiptment, point motors, train packs, scenery, signals switches, and much much more. Supplying model products along with reviews and advice.Railway Pictures - Railway photograph gallery covering all areas of railway traction, buildings, and trackwork. Extensive photo library, which is being added to weekly. Upload and share your own images to the site using its inbuilt upload features.Model Scalextric Shop - Slot Car Shop - www.newslotcarmodellers.co.uk - F1, A1, Ralley, Road, Endurance, Touring Cars, Track, Parts, Spares
New Slot Car Modellers - A slotcar website for people new to the hobby. Supplying practical advise and information to slot car modellers and racers as they develop their hobby.New Website Designer - New Website Designer's aim is to give basic practical advice about building your own website. The site takes you step by step through the process of picking your domain name, setting up your hosting, and building your website.milton keynes - your source for everything in milton keynes
Model Railway Shop
Hornby Model Railway Train Set - Caledonian Belle Train Set - R1151
Hornby Caledonian Belle Train Set
Train Set
£56
Hornby Model Railway Train Set - Goods Master Train Set - R1070
Hornby Goods Master Train Set
£74
Hornby Extension Track Pack A
£13.70
Hornby Extension Track Pack B
£22.70
Hornby Extension Track Pack C
£22.00
Hornby Extension Track Pack D
£35.00
Hornby Extension Track Pack E
£18.60
Hornby Extension Track Pack F
£22.80
