Hornby
Track Cleaning Coach (4 wheel coach)
Review
Hornby
(R696) Rating 5/10
The track
cleaning car is only really any good for maintaining a clean
track not for making a dirty track clean. This means they need
to be run regular. This Hornby model has a very fitting
maintenance livery which gives it true purpose for running.
Probably best to make up a maintenance train which on occasion
you bring out and run. The coach that has been used (4
wheel Coach) is fictional and was never built in reality.
This may put of some modellers that are looking for accuracy
above anything else.
This model
works by rubbing two abrasive pads which are spring loaded under
the car along the track. It is meant to be pushed rather than
pulled along but I find this leads to derailment at any minor
imperfection in the track. Best to pull it behind a shunter (or
any other powerful loco). I replaced the plastic wheels on my
older model with metal wheels which helps give the model weight.
The current model comes with metal wheels.
Overall I do think this model is worth buying
even though it is not a model of a real coach. I use mine often
on my layout and it does seem to work. As I said above you can
make up a maintenance train to pull several of these coaches
plus for example a
maintenance crane,
breakdown crane, or
flat bed wagon. Best to couple this coach directly behind
the loco to avoid derailment of the other coaches due to the
pads catching on any gaps in the track.
[back to the top]
