New Railway Modellers, the model railway website dedicated to beginners and those returning to the hobby, with basic and advanced model railway information on all aspects of the model railway Hobby.
Entire Web NRM
Home
Introduction
What train set to buy
Cost
Basic Tools
Base Board
Railway Track
Track Conversion
Building a Layout
Layout Designs
Members Layouts
Electronics
Digital Control (DCC)
Electronic Projects
Scenery
Plastic Kits
Rolling Stock
Maintenance
Service Sheets
Harry Potter
Thomas Tank Engine
7mm Narrow Gauge
Railway Software
Downloads
Photo Gallery
FAQ
Forums
Classified Ads
Railway Dictionary
Competitions
Links / Sponsors
Terms & Conditions
Contacts
 Scenery
Airbrushing
Ballast
Bridges
Buildings
Building Lighting
Grass
Hills
Inclines
Paint Conversion
Rock Faces
Hornby Skaledale
Railway Stations
Trees
Tarmac
Tunnels
Viaduct
Water
Finishing Touches
Electronic Projects
Railway Crossing
Building A Signal
Street Lights
Rolling Stock
Bachmann Wagons
Hornby Locomotives
Hornby Carriages
Hornby Wagons
Lima Locomotives
Lima Wagons
Loco Modification
Wagon Modification
Hornby Range Lists
Hornby Range 2006
Hornby Range 2007
Hornby Range 2008
Hornby Range 2009
Hornby Model Railway Brake Van Review
Worth Buying - This is an average model. The model has limitations and does not have a full range of mechanical or detailing features. For a railway model to be rated as "Worth Buying" a model must score between 4 and 7. Hornby LNER 20 Ton Brake Van (R6307A) Rating 6/10
The Hornby LNER 20 Ton Brake Van is an above average model but with scope for improvements. The cabin of this version is primarily painted brown with white highlights to represent railings. The chassis is all black with the same white highlights but this time to highlight the running boards
Hornby Model Railway LNER 20 Ton Brake Van (R6307A)
Some of the hand rails on this model are metal but the ones fitted to the cabin are moulded in place and have no gap between the rail and the cab. If these were made from metal and attached to the cab this model would have got a recommended rating. Its worth comparing the picture of this model to the one below.
The Hornby LNER 20 Ton Brake Van does have metal wheels, additional brake hoses and flush glazing, but it only has standard couplings and un-sprung buffers. Strangely this model has an unexpected level of detail under the model. It has the braking gear, worm gear and braking springs associated with a brake van. Unfortunately you cant see this when its in operation.
Worth Buying - This is an average model. The model has limitations and does not have a full range of mechanical or detailing features. For a railway model to be rated as "Worth Buying" a model must score between 4 and 7. Hornby BR 20 Ton Brake Van (R6350) Rating 6/10
The Hornby BR 20 Ton Brake Van is an above average model but with scope for improvements. The above review also applies to this model except when it comes to the livery. Personally the BR 20 Ton Brake Van is much more attractive and detailed with regard to livery than the LNER model.
Hornby Model Railway BR 20 Ton Brake Van (R6350)
This model has the normal overhead power warning signs and information boards. The thing that sticks out to me on this model is the bright yellow and black warning markings on both ends of the cab. This along with the red stripe really brings this model to life.
20 Ton Brake Van Pictures:  Visit Railway Pictures for more
Guards Van SR S55550
Hornby Model Railway Wagon Review - 75 Ton Breakdown Crane  R6204 Hornby Model Railway Wagon Review - ZXA Van R6265 Hornby Model Railway Wagon Review - HEA Hopper R6152b Hornby Model Railway Wagon Review ECC Closed China Clay Hopper R6106 and R6223 Hornby Model Railway Wagon Review - MGR Coal Hopper R6222 Hornby Model Railway Wagon Review MGR Coal Hopper with Canopy R6224 Hornby Model Railway Wagon Review Coalfish R6225 Hornby Model Railway Wagon Review - Maintenance Crane R6004 Hornby Model Railway Wagon Review - 4 Wheel Coach - Track Cleaning Car R296 Hornby Model Railway Wagon Review - V-Tanker R6153b Hornby Model Railway Wagon Review - LWB Tank Wagon (Water) R6081 Hornby Model Railway Wagon Review - Seacow Ballast Wagon R6286 Hornby Model Railway Wagon Review - GLW Steel Carrier R427 and R6209B Hornby Model Railway Wagon Review - 4 Wheel Coach Hornby Model Railway Wagon Review - 20 Ton Break Van R Hornby Model Railway Wagon Review BR Carflat Car Transporter R6143
Bachmann Locomotives
Bachmann Coaches
Bachmann Wagon
Hornby Locomotives
Hornby Coaches
Hornby Wagons
Heljan Locomotives
Lima Locomotives
Lima Wagons
Locomotive Modification
Wagon Modification
New Modellers Shop - A Model Railway Shop - Stocking model railway wagons, coaches, carriages, electric diesel and steam locomotives, power and control equiptment, point motors, train packs, scenery, signals switches, and much much more. Supplying model products along with reviews and advice.Railway Pictures - Railway photograph gallery covering all areas of railway traction, buildings, and trackwork. Extensive photo library, which is being added to weekly. Upload and share your own images to the site using its inbuilt upload features.Model Scalextric Shop - Slot Car Shop - www.newslotcarmodellers.co.uk - F1, A1, Ralley, Road, Endurance, Touring Cars, Track, Parts, Spares
New Slot Car Modellers - A slotcar website for people new to the hobby. Supplying practical advise and information to slot car modellers and racers as they develop their hobby.New Website Designer - New Website Designer's aim is to give basic practical advice about building your own website. The site takes you step by step through the process of picking your domain name, setting up your hosting, and building your website.milton keynes - your source for everything in milton keynes
Model Railway Shop
Hornby Model Railway Train Set - Local Freight Train Set - R1085
Hornby Local Freight
Train Set
£42
Hornby Model Railway Train Set - Goods Master Train Set - R1070
Hornby Goods Master Train Set
£74
Hornby Extension Track Pack A
£12.70
Hornby Extension Track Pack B
£21.00
Hornby Extension Track Pack C
£20.40
Hornby Extension Track Pack D
£32.60
Hornby Extension Track Pack E
£17.15
Hornby Extension Track Pack F
£21.15
