New Railway Modellers, the model railway website dedicated to beginners and those returning to the hobby, with basic and advanced model railway information on all aspects of the model railway Hobby.
Entire Web NRM
Home
Introduction
What train set to buy
Cost
Basic Tools
Base Board
Railway Track
Track Conversion
Building a Layout
Layout Designs
Members Layouts
Electronics
Digital Control (DCC)
Electronic Projects
Scenery
Plastic Kits
Rolling Stock
Maintenance
Service Sheets
Harry Potter
Thomas Tank Engine
7mm Narrow Gauge
Railway Software
Downloads
Photo Gallery
FAQ
Forums
Classified Ads
Railway Dictionary
Competitions
Links / Sponsors
Terms & Conditions
Contacts
 Scenery
Airbrushing
Ballast
Bridges
Buildings
Building Lighting
Grass
Hills
Inclines
Paint Conversion
Rock Faces
Hornby Skaledale
Railway Stations
Trees
Tarmac
Tunnels
Viaduct
Water
Finishing Touches
Electronic Projects
Railway Crossing
Building A Signal
Street Lights
Rolling Stock
Bachmann Wagons
Hornby Locomotives
Hornby Carriages
Hornby Wagons
Lima Locomotives
Lima Wagons
Loco Modification
Wagon Modification
Hornby Range Lists
Hornby Range 2006
Hornby Range 2007
Hornby Range 2008
Hornby Range 2009
Hornby Model Railway Locomotive Reviews -  Class 67
Worth Buying - This is an average model. The model has limitations and does not have a full range of mechanical or detailing features. For a railway model to be rated as "Worth Buying" a model must score between 4 and 7. Hornby Class 67 (Rising Star 67027) R5222 Rating  7/10
The Hornby class 67 is based on the Lima tooling acquired when Hornby purchased Lima. The class 67 is not the most beautiful locomotive but I cant hold this against the model.
Hornby Model Railway Reviews - Class 67 (Rising Star 67027) - R5222
Function: Although this model lacks some detail this model is fully fictional under the bonnet so to speak. The Hornby Class 67 comes with all wheel drive, powered by a 5 pole skew wound motor. This model is DCC Ready and comes with the usual DCC chip sleeve. It has no traction tires and and has pickups on all wheels. Tested on DC operation it had excellent slow speed control as well as a respectable top speed. The loco managed tight corners and standard points with no problem and seems to have more than enough power and weight to pull a descent sized train. I have not yet tested it on DCC operation but I would expect it to be very similar to DC operation
note: When also tested using a DCC controller using the DC control option it was very noisy and slow. I would not recommend this method of control but then as it is DCC ready it is simple enough to fit a DCC chip.
This model has directional front lights only. This is not necessarily a problem as it should spend most of its time pulling coaches or wagons.
Detail: At first glance it looks like a very highly detailed loco but when you look closer you realise that the grills are painted on and you cant see through them. The most detailed part of this model seems to be the bogies which do look nice.
This model only comes with standard tension lock couplings which can be removed if like me you prefer not to have a coupling on the front of the loco. Detailing features on this model include glazing flush with the body work, window wipers, detailing pack (includes break hoses chain couplings), moulded exhaust manifold, and detailed bogie. This model does not have sprung loaded buffers.
The interior of the cab is poor with no driver and no room for one to be put in because the floor of the cab is about the same height as the window. I believe this the result of the transfer box which transferring the power from the motor (mounted in the middle) to the bogie intruding in to the cab space.
Hornby 67 Features:
DCC Ready.
5 pole screw wound motor
All wheel Drive
All wheel pickup
Detailing parts
Directional Lights
Service Sheet: PDF ss-290-259 (208kb)
Overall:  I was tempted to give this model a "Recommended" rating but it had too many minor limitations (cab detail, standard couplings) that I could only give it 7 out of 10. I think it is unlikely that this model will be improved any more in the short turn as their are many other models crying out for retooling like the class 37, 56 (soon to be released), and 47.
Class 67 Pictures:
67002 67029 67006 67013 EWS
Available liveries:
RRP £70
RRP £70
[back to the top]
Diesel and Electric Review List
Hornby Model Railway Class 06 Review - BR Blue, Liveries Hornby Model Railway Class 08 Review - EWS, Loadhaul, Mainline, Trainload, Br Blue, Liveries Hornby Model Railway Class 09 Review - EWS, Loadhaul, Mainline, Trainload, Br Blue Liveries Hornby Model Railway Class 31 Review - BR Blue, Liveries Hornby Model Railway Class 37 Review - EWS, Loadhaul, Mainline, Trainload, BR Blue, Liveries Hornby Model Railway Class 47 Review - Virgin, BR, Liveries Hornby Model Railway Class 50 Review - NSE, BR, Liveries Hornby Model Railway Class 56 Review - Loadhaul, EWS, TrainLoad, BR, Transrail Liveries Hornby Model Railway Class 58 Review - EWS, Loadhaul, Mainline, Trainload, Transrail Liveries Hornby Model Railway Class 60 Review - EWS, Loadhaul, Mainline, Trainload, Liveries Hornby Model Railway Class 66 Review - EWS, GBrf Liveries Hornby Model Railway Class 67 Review - EWS, Royal train Hornby Model Railway Class 90 Review - EWS, Loadhaul, Mainline, Trainload, Transrail, Intercity, Liveries Hornby Model Railway Class 92 Review - EWS, Transrail, Liveries Hornby Model Railway Class 121 "Bubble Car" Review -  BR Blue, BR Green, Network Southest NSE Liveries Hornby Model Railway Class 142 Pacer Review Hornby Model Railway Class 153 Review - Central trains, Arriva, Reginal Railways Hornby Model Railway Class 390 Virgin Pendolino Review - Virgin Liveries Hornby Model Railway Class 373  Review - Eurostar, GNER White rose Liveries
Steam Locomotive Review List
Hornby Model Railway Class 0F 0-4-0ST  Review - BR, Smokey Joe liveries Hornby Model Railway Class A4  Review - LNER, Mallard, Silver Jubilee, South Africa, Sir Nigel Gresley
Thomas The Tank Engine And Friends
Hornby Model Railway Thomas The Tank engine And Friends, Annie and Clarabel  Review Hornby Model Railway Thomas The Tank Engine And Friends - Percy and 2 Troublesome Trucks Review Hornby Model Railway Thomas The Tank Engine And Friends - Toby and 3 Trucks Review
New Modellers Shop - A Model Railway Shop - Stocking model railway wagons, coaches, carriages, electric diesel and steam locomotives, power and control equiptment, point motors, train packs, scenery, signals switches, and much much more. Supplying model products along with reviews and advice.Railway Pictures - Railway photograph gallery covering all areas of railway traction, buildings, and trackwork. Extensive photo library, which is being added to weekly. Upload and share your own images to the site using its inbuilt upload features.Model Scalextric Shop - Slot Car Shop - www.newslotcarmodellers.co.uk - F1, A1, Ralley, Road, Endurance, Touring Cars, Track, Parts, Spares
New Slot Car Modellers - A slotcar website for people new to the hobby. Supplying practical advise and information to slot car modellers and racers as they develop their hobby.New Website Designer - New Website Designer's aim is to give basic practical advice about building your own website. The site takes you step by step through the process of picking your domain name, setting up your hosting, and building your website.milton keynes - your source for everything in milton keynes
Model Railway Shop
Hornby Model Railway Train Set - Local Freight Train Set - R1085
Hornby Local Freight
Train Set
£42
Hornby Model Railway Train Set - Goods Master Train Set - R1070
Hornby Goods Master Train Set
£74
Hornby Extension Track Pack A
£12.70
Hornby Extension Track Pack B
£21.00
Hornby Extension Track Pack C
£20.40
Hornby Extension Track Pack D
£32.60
Hornby Extension Track Pack E
£17.15
Hornby Extension Track Pack F
£21.15
