New Railway Modellers, the model railway website dedicated to beginners and those returning to the hobby, with basic and advanced model railway information on all aspects of the model railway Hobby.
Entire Web NRM
Home
Introduction
What train set to buy
Cost
Basic Tools
Base Board
Railway Track
Track Conversion
Building a Layout
Layout Designs
Members Layouts
Electronics
Digital Control (DCC)
Electronic Projects
Scenery
Plastic Kits
Rolling Stock
Maintenance
Service Sheets
Harry Potter
Thomas Tank Engine
7mm Narrow Gauge
Railway Software
Downloads
Photo Gallery
FAQ
Forums
Classified Ads
Railway Dictionary
Competitions
Links / Sponsors
Terms & Conditions
Contacts
 Scenery
Airbrushing
Ballast
Bridges
Buildings
Building Lighting
Grass
Hills
Inclines
Paint Conversion
Rock Faces
Hornby Skaledale
Railway Stations
Trees
Tarmac
Tunnels
Viaduct
Water
Finishing Touches
Electronic Projects
Railway Crossing
Building A Signal
Street Lights
Rolling Stock
Bachmann Wagons
Hornby Locomotives
Hornby Carriages
Hornby Wagons
Lima Locomotives
Lima Wagons
Loco Modification
Wagon Modification
Hornby Range Lists
Hornby Range 2006
Hornby Range 2007
Hornby Range 2008
Hornby Range 2009
Hornby Model Railway Locomotive Reviews -  Class 60
Recommended - This model is Recommended to purchase. Recommended models should be fully featured and have only a few minor mechanical or detailed limitations. For a railway model to be rated as "Recommended" a model must score 8 or more. Hornby Class 60 EWS (R2488) Rating 10/10 Great Model.... But you pay for it.
Visual Detail: The Hornby Class 60 pushed ready to run OO gauge locomotives to a new level. The attention to detail is fantastic. The locomotives engine is visible when you look through the grill including fine pipe work. The bogies as well as being fully functional with all wheel drive are fully detailed and include sand pipes.
Hornby Model Railway Class 60 EWS Locomotive R2488
Inside the cab you can see the locomotives dials and controls, which are all fully painted. The only down side to the cab is that it does not have a crew although in some cases this may be preferred. The windows have flush glazing and has window wipers on the front. All four of the cab doors are operational and spring loaded. I believe this is so you can place a man in the door without him falling off.
If you are planning to display this model Hornby have included some pipes and replacement snowplough, which replace the NEM couplings. They have also included some working chain couplings, which may be able to pull wagons.
The models directional lights are very impressive. The lights come on at the slightest current, which means you can stop the model and still have the lights on at full power. The front lights are bright enough to actually light the path of the model and looks great when driven into or out of a dark tunnel. The ability to change from night lighting to day lighting is a nice touch but for most modellers will be a feature they rarely use.
Performance: With pick up on all wheels and all wheel drive this locomotive out performs all the models I have previously encountered by a long way. Stalling is a thing of the past with this model. It can pull away smoothly at very slow realistic speeds without stalling and due to its all wheel drive and its considerable weight it can pull long trains with ease even though it has no traction tyres. The top speed of this model may not be as fast as others but is I believe still faster than the real life scale speed.
I love the sound this model makes. When it starts off it’s very quite but when it gets going you get this powerful rumbling noise, which is strangely satisfying.
Overall: This is a 'must have' model for any diesel model fans. I believe it will be very hard to surpass this model in detail and performance, for the same money.
Hornby Class 60 Features:
DCC Ready
NEM Coupling
Display Parts
Spring Buffers
Working directional lighting with the option to switch from day to night running
Painted and detailed cab interior
All wheel drive courtesy of a centrally mounted motor with duel axels sending power to both bogies.
Fitting A DCC Decoder Chip to the Hornby Class 60:
To remove the body you have to pull apart the bottom of the body of the loco. There are 8 clips which need to be dis-engaged for the body to lift off. Due to the weight of the chassis it is best to do this with the model on a firm flat surface (method suggested by Hornby). I found it best to rotate between the front and back clips of the model so as to slowly ease the body off. This took a bit of time and I think its best not to rush it.
Hornby Model Railway Class 60 EWS Locomotive R2488 - DCC Decoder Installation R8215
Hornby Model Railway Class 60 EWS Locomotive R2488 - DCC Decoder Installation R8215 - Before  Hornby Model Railway Class 60 EWS Locomotive R2488 - DCC Decoder Installation R8215 - After
Before     ----       After
Once the body is off it is a simple procedure to remove the dummy plug (can be seen at the bottom of the picture below) and insert the dcc decoder. Make sure the orange wire representing pin 1 goes into the socket marked 1 on the locomotive plug. This was very easy to locate. Once the decoder is installed slip the decoding chip and some of the trailing wire into the insulating sleeve which comes with the locomotive. This will stop it shorting and stop the decoder from getting caught in the axel from the motor to the bogie.
Last step is to program and test the model with your dcc controller. Only then would I put the body back on. Now your model is ready to be run on your dcc layout.
Available Liveries:
Hornby Model Railway Class 60 EWS R2488 Hornby Model Railway Class 60 Loadhaul R2489 Hornby Model Railway Class 60 Mainline R2490
 Hornby Model Railway Class 60 EWS R2488 Hornby Model Railway Class 60 Loadhaul R2489 Hornby Model Railway Class 60 Mainline R2490 Hornby Model Railway Class 60 Trainload R2677
[back to the top]
Diesel and Electric Review List
Hornby Model Railway Class 06 Review - BR Blue, Liveries Hornby Model Railway Class 08 Review - EWS, Loadhaul, Mainline, Trainload, Br Blue, Liveries Hornby Model Railway Class 09 Review - EWS, Loadhaul, Mainline, Trainload, Br Blue Liveries Hornby Model Railway Class 31 Review - BR Blue, Liveries Hornby Model Railway Class 37 Review - EWS, Loadhaul, Mainline, Trainload, BR Blue, Liveries Hornby Model Railway Class 47 Review - Virgin, BR, Liveries Hornby Model Railway Class 50 Review - NSE, BR, Liveries Hornby Model Railway Class 56 Review - Loadhaul, EWS, TrainLoad, BR, Transrail Liveries Hornby Model Railway Class 58 Review - EWS, Loadhaul, Mainline, Trainload, Transrail Liveries Hornby Model Railway Class 60 Review - EWS, Loadhaul, Mainline, Trainload, Liveries Hornby Model Railway Class 66 Review - EWS, GBrf Liveries Hornby Model Railway Class 67 Review - EWS, Royal train Hornby Model Railway Class 90 Review - EWS, Loadhaul, Mainline, Trainload, Transrail, Intercity, Liveries Hornby Model Railway Class 92 Review - EWS, Transrail, Liveries Hornby Model Railway Class 121 "Bubble Car" Review -  BR Blue, BR Green, Network Southest NSE Liveries Hornby Model Railway Class 142 Pacer Review Hornby Model Railway Class 153 Review - Central trains, Arriva, Reginal Railways Hornby Model Railway Class 390 Virgin Pendolino Review - Virgin Liveries Hornby Model Railway Class 373  Review - Eurostar, GNER White rose Liveries
Steam Locomotive Review List
Hornby Model Railway Class 0F 0-4-0ST  Review - BR, Smokey Joe liveries Hornby Model Railway Class A4  Review - LNER, Mallard, Silver Jubilee, South Africa, Sir Nigel Gresley
Thomas The Tank Engine And Friends
Hornby Model Railway Thomas The Tank engine And Friends, Annie and Clarabel  Review Hornby Model Railway Thomas The Tank Engine And Friends - Percy and 2 Troublesome Trucks Review Hornby Model Railway Thomas The Tank Engine And Friends - Toby and 3 Trucks Review
New Modellers Shop - A Model Railway Shop - Stocking model railway wagons, coaches, carriages, electric diesel and steam locomotives, power and control equiptment, point motors, train packs, scenery, signals switches, and much much more. Supplying model products along with reviews and advice.Railway Pictures - Railway photograph gallery covering all areas of railway traction, buildings, and trackwork. Extensive photo library, which is being added to weekly. Upload and share your own images to the site using its inbuilt upload features.Model Scalextric Shop - Slot Car Shop - www.newslotcarmodellers.co.uk - F1, A1, Ralley, Road, Endurance, Touring Cars, Track, Parts, Spares
New Slot Car Modellers - A slotcar website for people new to the hobby. Supplying practical advise and information to slot car modellers and racers as they develop their hobby.New Website Designer - New Website Designer's aim is to give basic practical advice about building your own website. The site takes you step by step through the process of picking your domain name, setting up your hosting, and building your website.milton keynes - your source for everything in milton keynes
Model Railway Shop
Hornby Model Railway Train Set - Local Freight Train Set - R1085
Hornby Local Freight
Train Set
£40
Hornby Model Railway Train Set - Goods Master Train Set - R1070
Hornby Goods Master Train Set
£64
Hornby Extension Track Pack A
£9.80
Hornby Extension Track Pack B
£16.15
Hornby Extension Track Pack C
£15.75
Hornby Extension Track Pack D
£25.15
Hornby Extension Track Pack E
£13.25
Hornby Extension Track Pack F
£16.35
