New Railway Modellers, the model railway website dedicated to beginners and those returning to the hobby, with basic and advanced model railway information on all aspects of the model railway Hobby.
Entire Web NRM
Home
Introduction
What train set to buy
Cost
Basic Tools
Base Board
Railway Track
Track Conversion
Building a Layout
Layout Designs
Members Layouts
Electronics
Digital Control (DCC)
Electronic Projects
Scenery
Plastic Kits
Rolling Stock
Maintenance
Service Sheets
Harry Potter
Thomas Tank Engine
7mm Narrow Gauge
Railway Software
Downloads
Photo Gallery
FAQ
Forums
Classified Ads
Railway Dictionary
Competitions
Links / Sponsors
Terms & Conditions
Contacts
 Scenery
Airbrushing
Ballast
Bridges
Buildings
Building Lighting
Grass
Hills
Inclines
Paint Conversion
Rock Faces
Hornby Skaledale
Railway Stations
Trees
Tarmac
Tunnels
Viaduct
Water
Finishing Touches
Electronic Projects
Railway Crossing
Building A Signal
Street Lights
Rolling Stock
Bachmann Wagons
Hornby Locomotives
Hornby Carriages
Hornby Wagons
Lima Locomotives
Lima Wagons
Loco Modification
Wagon Modification
Hornby Range Lists
Hornby Range 2006
Hornby Range 2007
Hornby Range 2008
Hornby Range 2009
Hornby Model Railway Locomotive Reviews -  Class 31
Author "Peak" (forum member)
Recommended - This model is Recommended to purchase. Recommended models should be fully featured and have only a few minor mechanical or detailed limitations. For a railway model to be rated as "Recommended" a model must score 8 or more. Hornby Class 31 (BR Blue weathered 31111) R2571 Rating  9/10
First impressions:
The model comes in a well-packed box, which protects the model from damage. It cost £55 from my local model railway shop. The packaging is easily removed without damage to the model.
Included in the box were,
1. Instruction sheet.
2. Additional parts. Couplings, pipes and discs.
Detail: A quick look over the model proves it is very finely detailed with handrails and grab handles standing proud, especially on the roof (care must be taken not to damage these.) Bogies are also finely detailed. The model looks very much like a 31 although I have not measured it. The doors open and there is a working fan. There are also working directional lights. The model is finished in weathered rail blue with labels clearly printed, as are the numbers, the blue star codes are also clear on the face of the loco. The weathering is light but not so good on the bogies. A nice touch is that you can see the path of the window wipers as they have cleaned away the dirt!
I have fitted the pipes etc to one end of the loco (This is quite a fidderly task but well worth the effort) and the small Hornby coupling to the other.
Function: The loco has drive to all wheels and also pickups to all wheels. The loco’s performance is smooth and quite with excellent slow speed response. The loco easily coped with nine Bachmann Mrk 1s even up my gradients.
Hornby Class 31 Features:
DCC Ready.
5 pole screw wound motor
All Wheel drive (Twin Bogie Drive)
All wheel pickup
Detailing parts
NEM Couplings
Sprung Buffers
Service Sheet: PDF ss-276D (128kb)
Decoder Fitting: I have fitted a Bachmann 3 function decoder to this loco which required the removal of the body. There are 4 screws to remove and you have to turn the bogies to get access to these, however I found that removal of theses screws was not possible, as the bogies do not turn enough! I had to remove the chassis from an upside down body leaving the loose screws in the chassis. There is an 8-pin DCC socket provided and plenty of room for the decoder underneath the circuit board.
Overall: Over all I would give this model 9 out of 10 with it only being let down by the bogie weathering. Hornby must be praised for there efforts with this loco, I would recommend it.
Class 31 Pictures:
31 545 Manchester Victoria 24-07-1991 31 464 Doncaster 16-07-1990 31413 31454 & 31106 31149 31 31125 31271
Available liveries:
R2421 - BR Class 31 CE 31110
Hornby Model Railway Review - R2421 - BR Class 31 CE 31110
R2413 - R2413 BR Class 31 31270 Weathered
Hornby Model Railway Review - R2413 BR Class 31 31270 Weathered
R2649 - R2649 BR A1A-A1A Class 31 31165
Hornby Model Railway Review - R2649 BR A1A-A1A Class 31 31165
R2420 - BR Class 31 BR Green D5512
Hornby Model Railway Review - R2420 BR Class 31 BR Green D5512
R2572 - R2572 BR Class 31 BR Green
Hornby Model Railway Review - R2572 BR Class 31 BR Green
R2573 -  R2573 BR Class 31 Fragonset
Hornby Model Railway Review - R2573 BR Class 31 Fragonset
R2571 -R2571 BR Blue Class 31
Hornby Model Railway Review - R2571 BR Blue Class 31
[back to the top]
Diesel and Electric Review List
Hornby Model Railway Class 06 Review - BR Blue, Liveries Hornby Model Railway Class 08 Review - EWS, Loadhaul, Mainline, Trainload, Br Blue, Liveries Hornby Model Railway Class 09 Review - EWS, Loadhaul, Mainline, Trainload, Br Blue Liveries Hornby Model Railway Class 31 Review - BR Blue, Liveries Hornby Model Railway Class 37 Review - EWS, Loadhaul, Mainline, Trainload, BR Blue, Liveries Hornby Model Railway Class 47 Review - Virgin, BR, Liveries Hornby Model Railway Class 50 Review - NSE, BR, Liveries Hornby Model Railway Class 56 Review - Loadhaul, EWS, TrainLoad, BR, Transrail Liveries Hornby Model Railway Class 58 Review - EWS, Loadhaul, Mainline, Trainload, Transrail Liveries Hornby Model Railway Class 60 Review - EWS, Loadhaul, Mainline, Trainload, Liveries Hornby Model Railway Class 66 Review - EWS, GBrf Liveries Hornby Model Railway Class 67 Review - EWS, Royal train Hornby Model Railway Class 90 Review - EWS, Loadhaul, Mainline, Trainload, Transrail, Intercity, Liveries Hornby Model Railway Class 92 Review - EWS, Transrail, Liveries Hornby Model Railway Class 121 "Bubble Car" Review -  BR Blue, BR Green, Network Southest NSE Liveries Hornby Model Railway Class 142 Pacer Review Hornby Model Railway Class 153 Review - Central trains, Arriva, Reginal Railways Hornby Model Railway Class 390 Virgin Pendolino Review - Virgin Liveries Hornby Model Railway Class 373  Review - Eurostar, GNER White rose Liveries
Steam Locomotive Review List
Hornby Model Railway Class 0F 0-4-0ST  Review - BR, Smokey Joe liveries Hornby Model Railway Class A4  Review - LNER, Mallard, Silver Jubilee, South Africa, Sir Nigel Gresley
Thomas The Tank Engine And Friends
Hornby Model Railway Thomas The Tank engine And Friends, Annie and Clarabel  Review Hornby Model Railway Thomas The Tank Engine And Friends - Percy and 2 Troublesome Trucks Review Hornby Model Railway Thomas The Tank Engine And Friends - Toby and 3 Trucks Review
New Modellers Shop - A Model Railway Shop - Stocking model railway wagons, coaches, carriages, electric diesel and steam locomotives, power and control equiptment, point motors, train packs, scenery, signals switches, and much much more. Supplying model products along with reviews and advice.Railway Pictures - Railway photograph gallery covering all areas of railway traction, buildings, and trackwork. Extensive photo library, which is being added to weekly. Upload and share your own images to the site using its inbuilt upload features.Model Scalextric Shop - Slot Car Shop - www.newslotcarmodellers.co.uk - F1, A1, Ralley, Road, Endurance, Touring Cars, Track, Parts, Spares
New Slot Car Modellers - A slotcar website for people new to the hobby. Supplying practical advise and information to slot car modellers and racers as they develop their hobby.New Website Designer - New Website Designer's aim is to give basic practical advice about building your own website. The site takes you step by step through the process of picking your domain name, setting up your hosting, and building your website.milton keynes - your source for everything in milton keynes
Model Railway Shop
Hornby Model Railway Train Set - Local Freight Train Set - R1085
Hornby Local Freight
Train Set
£42
Hornby Model Railway Train Set - Goods Master Train Set - R1070
Hornby Goods Master Train Set
£74
Hornby Extension Track Pack A
£12.70
Hornby Extension Track Pack B
£21.00
Hornby Extension Track Pack C
£20.40
Hornby Extension Track Pack D
£32.60
Hornby Extension Track Pack E
£17.15
Hornby Extension Track Pack F
£21.15
