New Railway Modellers, the model railway website dedicated to beginners and those returning to the hobby, with basic and advanced model railway information on all aspects of the model railway Hobby.
Entire Web NRM
Home
Introduction
What train set to buy
Cost
Basic Tools
Base Board
Railway Track
Track Conversion
Building a Layout
Layout Designs
Members Layouts
Electronics
Digital Control (DCC)
Electronic Projects
Scenery
Plastic Kits
Rolling Stock
Maintenance
Service Sheets
Harry Potter
Thomas Tank Engine
7mm Narrow Gauge
Railway Software
Downloads
Photo Gallery
FAQ
Forums
Classified Ads
Railway Dictionary
Competitions
Links / Sponsors
Terms & Conditions
Contacts
 Scenery
Airbrushing
Ballast
Bridges
Buildings
Building Lighting
Grass
Hills
Inclines
Paint Conversion
Rock Faces
Hornby Skaledale
Railway Stations
Trees
Tarmac
Tunnels
Viaduct
Water
Finishing Touches
Electronic Projects
Railway Crossing
Building A Signal
Street Lights
Rolling Stock
Bachmann Wagons
Hornby Locomotives
Hornby Carriages
Hornby Wagons
Lima Locomotives
Lima Wagons
Loco Modification
Wagon Modification
Hornby Range Lists
Hornby Range 2006
Hornby Range 2007
Hornby Range 2008
Hornby Range 2009
Hornby Range 2010
Hornby Range 2011
Hornby Model Railway Locomotive Reviews -  Class 142 "Pacer"
Author "Metrocamel" (forum member)
Worth Buying - This is an average model. The model has limitations and does not have a full range of mechanical or detailing features. For a railway model to be rated as "Worth Buying" a model must score between 4 and 7. Hornby Class 142 "Pacer" (old version - one motor) R2571 Rating  6/10
Writing this I can already see half the forum turning in disgust at the mention of the Class 142 and it's Hornby counterpart. There are however plenty of people who like the "Nodding Donkey" and would like a review.
(142065 at rest)
My model is an example of the second attempt at a Pacer by Hornby. The original had a motor in each car and proved to be unreliable a the motors often ran out of sync. Mine is the later single motor version though it too has now been superseded by a new DCC fitted model (although this is restricted to a single livery at present).
Outwardly Hornby's effort is reasonable. The cab ends look the part (but would benefit from lights). The body sides and roof too are well made and covered with rivets like the real thing! The only thing I dislike about the appearance is the interior. It's a one piece beige plastic block with seats on it that rises up behind the doors on both sides and makes the model look like someone has been sick enough times to fill the gangways with vomit! The doors are also double folding type (I'm pretty sure this type of door was a thing of the past by the time Northern spirit took over and they certainly are now). Glazing is flush and the livery is well applied with legible Northern Spirit lettering, running numbers and destination boards reading "Sunderland" (home sweet home!)
142065 takes on fuel at Octane Vale TMD.
The interior moulding clearly rises above the doors and makes the floor look ridiculously high.
The under frame is reasonable and looks 142ish. On the rails the model performs as you'd expect. It rattles, shakes and squeals just like a real Pacer. While this could be dismissed as "authentic" it stops the model being reliable. On curves the 142 slows to a crawl if it's at a normal running speed. This forces the operator to put his foot (or finger) down and power up on these parts of the Layout, slowing carefully to avoid the sudden burst of speed when the units reach the next straight! A challenge to drive perhaps but if you're planning on sitting back and watching you've got another thing coming!
My 142 runs very jerkily though this is more likely due to lack of track and wheel maintenance.
The unit's pickups are on both cars and on three axles (the powered axle being fitted with traction tyres). The pickups should be adequate and are well spread out but still the model continues to stutter. I can't fault Hornby's efforts here as there are no more axles to pick up the power from the track.
The coupling between cars is a semi permanent clip which also provides an electrical connection. It's a nice bit of kit and would benefit many other types of unit like the Lima/Hornby 156.
Class History - http://en.wikipedia.org/wiki/British_Rail_Class_142
Liveries produced - Regional rail grey, Regional rail yellow, Manchester PTE orange, Provincial blue, Northern Spirit Turquoise (there were some others including a brown/cream livery and a grey/red one, if anyone can name them I'd be grateful)
* I can't be sure which of these were the one motor type and which were the earlier two motor.
Available from - Second hand market
Upgrading the model - Branchlines do a replacement chassis with new drive and compensation units. There are also replacement doors available to correct the double folding ones on the Hornby model which were replaced with two rigid folding on later liveries. Express models also do a lighting system for every occasion, DC and DCC!
Good points
  • Good Points
  • Liveries,
  • overall appearance,
  • interesting unit.
Bad points
  • Running on curves,
  • Pickups,
  • Interior.
Overall - I'd rate this model a 6 out of 10. It's appearance is mostly ok minus the interior but running really lets it down. Once again I must stress that this is not Hornby's fault. The real thing has just as many cornering problems and with just four axles there isn't much room from pickups. Removing the traction tyres in favour of more pickups would likely make the Pacer a nightmare on gradients (and it probably already is!).
Branchlines chassis could improve this model but are expensive and I doubt whether they'd improve things much within the limitations of the long wheelbase (although I think they do offer flywheels). With some lights, weathering and maybe even some kadee couplings to model the four car sets this model might even get a recommended rating. The 142 is nonetheless a unique unit and a must for modern image!
Rating- 6/10.
Class 142 Pacer Pictures:
142065 142007 142093 142050 142011 at Ashton - under - Lyne (21/1/08) 142092 at Manchester Piccadilly (21/1/08) 142 062 Doncaster 29-03-2005 Class 142's at Sheffield
Available liveries:
Hornby Model Railway Review - R2700 Arriva Pacer Class 142
Hornby Model Railway Review - R2611 Mersey Railway Pacer Class 142
[back to the top]
Diesel and Electric Review List
Hornby Model Railway Class 06 Review - BR Blue, Liveries Hornby Model Railway Class 08 Review - EWS, Loadhaul, Mainline, Trainload, Br Blue, Liveries Hornby Model Railway Class 09 Review - EWS, Loadhaul, Mainline, Trainload, Br Blue Liveries Hornby Model Railway Class 31 Review - BR Blue, Liveries Hornby Model Railway Class 37 Review - EWS, Loadhaul, Mainline, Trainload, BR Blue, Liveries Hornby Model Railway Class 47 Review - Virgin, BR, Liveries Hornby Model Railway Class 50 Review - NSE, BR, Liveries Hornby Model Railway Class 56 Review - Loadhaul, EWS, TrainLoad, BR, Transrail Liveries Hornby Model Railway Class 58 Review - EWS, Loadhaul, Mainline, Trainload, Transrail Liveries Hornby Model Railway Class 60 Review - EWS, Loadhaul, Mainline, Trainload, Liveries Hornby Model Railway Class 66 Review - EWS, GBrf Liveries Hornby Model Railway Class 67 Review - EWS, Royal train Hornby Model Railway Class 90 Review - EWS, Loadhaul, Mainline, Trainload, Transrail, Intercity, Liveries Hornby Model Railway Class 92 Review - EWS, Transrail, Liveries Hornby Model Railway Class 121 "Bubble Car" Review -  BR Blue, BR Green, Network Southest NSE Liveries Hornby Model Railway Class 142 Pacer Review Hornby Model Railway Class 153 Review - Central trains, Arriva, Reginal Railways Hornby Model Railway Class 390 Virgin Pendolino Review - Virgin Liveries Hornby Model Railway Class 373  Review - Eurostar, GNER White rose Liveries
Steam Locomotive Review List
Hornby Model Railway Class 0F 0-4-0ST  Review - BR, Smokey Joe liveries Hornby Model Railway Class A4  Review - LNER, Mallard, Silver Jubilee, South Africa, Sir Nigel Gresley
Thomas The Tank Engine And Friends
Hornby Model Railway Thomas The Tank engine And Friends, Annie and Clarabel  Review Hornby Model Railway Thomas The Tank Engine And Friends - Percy and 2 Troublesome Trucks Review Hornby Model Railway Thomas The Tank Engine And Friends - Toby and 3 Trucks Review
New Modellers Shop - A Model Railway Shop - Stocking model railway wagons, coaches, carriages, electric diesel and steam locomotives, power and control equiptment, point motors, train packs, scenery, signals switches, and much much more. Supplying model products along with reviews and advice.Railway Pictures - Railway photograph gallery covering all areas of railway traction, buildings, and trackwork. Extensive photo library, which is being added to weekly. Upload and share your own images to the site using its inbuilt upload features.Model Scalextric Shop - Slot Car Shop - www.newslotcarmodellers.co.uk - F1, A1, Ralley, Road, Endurance, Touring Cars, Track, Parts, Spares
New Slot Car Modellers - A slotcar website for people new to the hobby. Supplying practical advise and information to slot car modellers and racers as they develop their hobby.New Website Designer - New Website Designer's aim is to give basic practical advice about building your own website. The site takes you step by step through the process of picking your domain name, setting up your hosting, and building your website.
Model Railway Shop
Hornby Model Railway Train Set - Caledonian Belle Train Set - R1151
Hornby Caledonian Belle Train Set
Train Set
£56
Hornby Model Railway Train Set - Goods Master Train Set - R1070
Hornby Goods Master Train Set
£74
Hornby Extension Track Pack A
£13.70
Hornby Extension Track Pack B
£22.70
Hornby Extension Track Pack C
£22.00
Hornby Extension Track Pack D
£35.00
Hornby Extension Track Pack E
£18.60
Hornby Extension Track Pack F
£22.80
