New Railway Modellers, the model railway website dedicated to beginners and those returning to the hobby, with basic and advanced model railway information on all aspects of the model railway Hobby.
Entire Web NRM
Home
Introduction
What train set to buy
Cost
Basic Tools
Base Board
Railway Track
Track Conversion
Building a Layout
Layout Designs
Members Layouts
Electronics
Digital Control (DCC)
Electronic Projects
Scenery
Plastic Kits
Rolling Stock
Maintenance
Service Sheets
Harry Potter
Thomas Tank Engine
7mm Narrow Gauge
Railway Software
Downloads
Photo Gallery
FAQ
Forums
Classified Ads
Railway Dictionary
Competitions
Links / Sponsors
Terms & Conditions
Contacts
 Scenery
Airbrushing
Ballast
Bridges
Buildings
Building Lighting
Grass
Hills
Inclines
Paint Conversion
Rock Faces
Hornby Skaledale
Railway Stations
Trees
Tarmac
Tunnels
Viaduct
Water
Finishing Touches
Electronic Projects
Railway Crossing
Building A Signal
Street Lights
Rolling Stock
Bachmann Wagons
Hornby Locomotives
Hornby Carriages
Hornby Wagons
Lima Locomotives
Lima Wagons
Loco Modification
Wagon Modification
Hornby Range Lists
Hornby Range 2006
Hornby Range 2007
Hornby Range 2008
Hornby Range 2009
Hornby Range 2010
Hornby Range 2011
Heljan Model Railway Locomotive Reviews -  Class 58
Author "Metrocamel" (forum member)
Recommended - This model is Recommended to purchase. Recommended models should be fully featured and have only a few minor mechanical or detailed limitations. For a railway model to be rated as "Recommended" a model must score 8 or more. Heljan Class 58 Locomotive Rating 9/10
Having finally got round to buying a successor to my much loved Hornby model here's a review of the Heljan Class 58. First of all this model has received much criticism from various parties and I wish to make clear that much of this is (in my opinion) unjustified nit picking.
Detail: The model looks like the bulky, modular "58" it represents. All the detail on the body sides is there with the multitude of doors and fittings all rendered very well. Much criticism has been made of the lack of mesh grilles but the moulded ones fitted actually lend themselves incredibly well to the prototype. The grilles are very fine and the X shaped struts behind are cleverly rendered as if in relief to create more depth.
My only issue here is the painting of all these grilles in the same colour as the body side when they were dark grey, almost black on the prototype. This issue is repeated on the doors which are a continued theme of the Rf grey livery when they too should have been black.
The roof depicts the odd looking "58" silencer very well and the two fan grilles are see through mesh with the fans beneath. Heljan has been slammed for not providing working fans but they're far from essential and those provided look the part.
Cab fronts are the best area of the model and have well made multiple working cables separately fitted and incredibly good wire handrails miles ahead of Hornby's moulds. the body side handrails are also good.
Buffer beam detail if nice but can be a tad tricky to remove. The scale coupling is nice and loose and swings realistically as the loco clatters through point work.
Minor things that are noteworthy are the numbers, for some reason printed with the 58 in the number as bold type. Not really noticeable but still odd. Also noticeable are the open cab windows, one at either end on the sides. What were Heljan thinking here? Had they simply left all windows shut the model would have looked fine, opening them exposes the thickness of the glazing which looks ludicrous if you look close enough.
In the same area the cab interior is very crude compared with what is available elsewhere. Thankfully this isn't too noticable but if you're planning on adding a crewman to the cab he'll have to be sliced in half at the waist.
Below the body the chassis is well detailed enough for me at least, although some seem to have disliked the bogies which could possibly have had more relief.
Performance: Performance wise the “58” is a powerhouse of a loco. Heljan’s AIA-AIA configuration (the outer axles of both bogies powered) is plenty and very strong. On the downside it seems to stall more readily than my other high spec diesels, but that’s probably down to my track cleaning!
A word should be made on couplings, an area in which Heljan are ahead of the competition. Compared with Hornby’s body mounted NEM pockets on springs (which derail wagons at every possible opportunity) Heljan’s version, mounted on a flexible plastic arm is very reliable and usable.
Features:
The biggest downside to this great model is in my opinion the lighting. In forward motion it’s good, although not up to the standards of modern Hornby offerings. However the rear tail lights bleed into the headlight on one side making it look like there are two tail lights and one much dimmer third light. The white headlights also illuminate on both ends at some higher speeds, though I’m told this is a fixable issue.
The model is DCC ready although the decoder socket is not marked with pin one, I had to guess orientation and look to see if the lights were on in order to get it right.
The above is best done with the body off, as removing it even once is migraine inducing! There are four clips holding the heavy chassis block in place but even if you do, for a brief time have them all unlocked the thing still needed a screwdriver to prise it off.
Overall: This model is much improved over the Hornby offering and many of the issues people have had with it (lack of mesh grilles on body sides and incorrect number printing) are trivial. It looks like a “58” and performs like one, and by this fact it is a good model.
Rating- 9/10
Plus: looks, detail, performance, couplings, improves on Hornby model.
Minus: erratic lighting, open windows, poor cab interior, body shell difficult to remove.
[back to the top]
Diesel Locomotive Review List
Heljan Model Railway Locomotive Reviews -  Class 57 Model Railway Review - Heljan Class 57 Locomotive - First Great Western (5704)
Bachmann Locomotives
Bachmann Coaches
Bachmann Wagon
Hornby Locomotives
Hornby Coaches
Hornby Wagons
Heljan Locomotives
Lima Locomotives
Lima Wagons
Locomotive Modification
Wagon Modification
New Modellers Shop - A Model Railway Shop - Stocking model railway wagons, coaches, carriages, electric diesel and steam locomotives, power and control equiptment, point motors, train packs, scenery, signals switches, and much much more. Supplying model products along with reviews and advice.Railway Pictures - Railway photograph gallery covering all areas of railway traction, buildings, and trackwork. Extensive photo library, which is being added to weekly. Upload and share your own images to the site using its inbuilt upload features.Model Scalextric Shop - Slot Car Shop - www.newslotcarmodellers.co.uk - F1, A1, Ralley, Road, Endurance, Touring Cars, Track, Parts, Spares
New Slot Car Modellers - A slotcar website for people new to the hobby. Supplying practical advise and information to slot car modellers and racers as they develop their hobby.New Website Designer - New Website Designer's aim is to give basic practical advice about building your own website. The site takes you step by step through the process of picking your domain name, setting up your hosting, and building your website.milton keynes - your source for everything in milton keynes
Model Railway Shop
Hornby Model Railway Train Set - Caledonian Belle Train Set - R1151
Hornby Caledonian Belle Train Set
Train Set
£56
Hornby Model Railway Train Set - Goods Master Train Set - R1070
Hornby Goods Master Train Set
£74
Hornby Extension Track Pack A
£13.70
Hornby Extension Track Pack B
£22.70
Hornby Extension Track Pack C
£22.00
Hornby Extension Track Pack D
£35.00
Hornby Extension Track Pack E
£18.60
Hornby Extension Track Pack F
£22.80
