New Railway Modellers, the model railway website dedicated to beginners and those returning to the hobby, with basic and advanced model railway information on all aspects of the model railway Hobby.
Entire Web NRM
Home
Introduction
What train set to buy
Cost
Basic Tools
Base Board
Railway Track
Track Conversion
Building a Layout
Layout Designs
Members Layouts
Electronics
Digital Control (DCC)
Electronic Projects
Scenery
Plastic Kits
Rolling Stock
Maintenance
Service Sheets
Harry Potter
Thomas Tank Engine
7mm Narrow Gauge
Railway Software
Downloads
Photo Gallery
FAQ
Forums
Classified Ads
Railway Dictionary
Competitions
Links / Sponsors
Terms & Conditions
Contacts
 Scenery
Airbrushing
Ballast
Bridges
Buildings
Building Lighting
Grass
Hills
Inclines
Paint Conversion
Rock Faces
Hornby Skaledale
Railway Stations
Trees
Tarmac
Tunnels
Viaduct
Water
Finishing Touches
Electronic Projects
Railway Crossing
Building A Signal
Street Lights
Rolling Stock
Bachmann Wagons
Hornby Locomotives
Hornby Carriages
Hornby Wagons
Lima Locomotives
Lima Wagons
Loco Modification
Wagon Modification
Hornby Range Lists
Hornby Range 2006
Hornby Range 2007
Hornby Range 2008
Hornby Range 2009
Hornby Range 2010
Hornby Range 2011
Bachmann Model Railway Locomotive Reviews -  9F
Author "Daniel Hull" (forum member)
Recommended - This model is Recommended to purchase. Recommended models should be fully featured and have only a few minor mechanical or detailed limitations. For a railway model to be rated as "Recommended" a model must score 8 or more. Bachmann 00 BR 9F 2-10-0 "NRM Evening Star (32-850)" Rating 9/10
The 9F was the biggest of all the standard locomotives, using a 2-10-0 wheel arrangement. It was developed for heavy freight, mainly bulk loads. One of them, 92203 holds the record for the heaviest load ever moved on a British line. They were designated as freight locomotives, well known for such freight workings as the Windcutter trains of mineral wagons on the Great Central, however they did also see some passenger turns fairly regularly, even hauling the Pines Express on occasion. It is even said that these small wheeled locomotives could reach 90mph regularly on the Great Central passenger turns.
Bachmann 00 BR 9F 2-10-0 "NRM Evening Star (32-850)" Review
Anyway to the model, looks great doesn’t it? and it looks even more amazing when you actually have it in front of you.
Now the first point I’ll make with this 9F is the turning circle, it will not go round 1st radius track, and it’s obvious why, it’s got 10 coupled driving wheels, even though just like the real thing the middle axle has no flanges, it will not go round the tight corners. Saying this it will very happily go round 2nd radius curves and over twisty trackwork. Due to the weight of the locomotive it is very much planted over points, and on my layout none of them are electrofrog. I’ve had no stalling issues with it either, even though it has no tender pick ups, which is a minus of Bachmann locomotives, because as far as I know none of them have tender pick ups.
I’d recommend if you intend on buying one of these make sure you have a large layout, or at least one with wide curves to stop it from looking unrealistic, in fact talking of unrealistic it brings me onto the one problem I have with this model, the tender on it’s closest coupling setting seems too far from the locomotive, have a look above and see what you think. I’m starting to live with it now, but I don’t think it’s right.
Having said all this the detail of the model is fantastic, the version I have is the NRM Evening Star (32-850) (pictured above) it’s becoming rarer now and expect to pay over the odds for it, but I found it in a model shop where it was the same price as the black ones so it was a no brainer. Evening Star comes with metal name plates to go over the printed ones and it certainly looks fabulous.
You can see in the photo above there is a lot of detail, far more than the Hornby 9F, just compare the front pony truck and you’ll see an obvious example of what I mean. The loco ran smoothly straight from the box and will haul a scale length train with ease. My layout has gradients on it, not inclines, and the 9F will happily haul upwards of 25 wagons once it gets going. It has quite a lot of momentum for a 00 engine, due to the flywheel, even with an instant cut of power the Bachmann 9F will bring the train to a stop smoothly insuring all wagons don’t crash into one another or fall off the track.
There are a few variants of the standard black 9F’s available, the main difference is the tender types you can have, there are BR1B, BR1C and BR1G, also there are weathered and non weathered, single or double chimney versions.
For those of you who have DCC layouts its DCC ready and a DCC fitted version is available, be it for a lot more money, in fact the topic of the price is important. This model has been out for a couple of years now and you can still find new ones for around £90 - £100, my one cost me £95, but Bachmann's latest price list has them at £120 - £130 and £142 for the DCC fitted one, this is very steep so I urge anyone to buy as soon as possible.
Bachmann Class 9F Features:
Flywheel drive
Sprung buffers
NEM couplings
Metal nameplates (evening star only)
DCC ready or fitted
Overall: To recap: It’s a good hauler, able to pull scale length trains at scale speeds, the tender – loco gap maybe a little bit big, the detail is fantastic, it runs well even out the box due to the flywheel, DCC ready, with many variations of the model and remember if you think you want one decide fast because prices are going up!
I give this model 9/10, it is very good, but I’d say let down by the gap between the loco and tender.
Class 9F Pictures:
 92203 Black Prince
[back to the top]
Bachmann Diesel and Electric Review List
Model Railway Review - Bachmann Class 66 - EWS, Freightliner, DRS, GGRF, Virgin Model Railway Review - Bachmann Class 66 - EWS, Freightliner, DRS, GGRF Model Railway Review - Bachmann Class 158 2-Car DMU - (31-026) Model Railway Review - Bachmann Class 166 3-Car DMU - Thames Trains (31-026)
Steam Locomotive Review List
Model Railway Review - Bachmann 00 BR 9F 2-10-0 "NRM Evening Star (32-850)" Review Model Railway Review - Bachmann 00 BR Standard 76000 4MT (32-592) Bachmann Model Railway Locomotive Reviews - J39
Bachmann Locomotives
Bachmann Coaches
Bachmann Wagon
Hornby Locomotives
Hornby Coaches
Hornby Wagons
Heljan Locomotives
Lima Locomotives
Lima Wagons
Locomotive Modification
Wagon Modification
New Modellers Shop - A Model Railway Shop - Stocking model railway wagons, coaches, carriages, electric diesel and steam locomotives, power and control equiptment, point motors, train packs, scenery, signals switches, and much much more. Supplying model products along with reviews and advice.Railway Pictures - Railway photograph gallery covering all areas of railway traction, buildings, and trackwork. Extensive photo library, which is being added to weekly. Upload and share your own images to the site using its inbuilt upload features.Model Scalextric Shop - Slot Car Shop - www.newslotcarmodellers.co.uk - F1, A1, Ralley, Road, Endurance, Touring Cars, Track, Parts, Spares
New Slot Car Modellers - A slotcar website for people new to the hobby. Supplying practical advise and information to slot car modellers and racers as they develop their hobby.New Website Designer - New Website Designer's aim is to give basic practical advice about building your own website. The site takes you step by step through the process of picking your domain name, setting up your hosting, and building your website.milton keynes - your source for everything in milton keynes
Model Railway Shop
Hornby Model Railway Train Set - Caledonian Belle Train Set - R1151
Hornby Caledonian Belle Train Set
Train Set
£56
Hornby Model Railway Train Set - Goods Master Train Set - R1070
Hornby Goods Master Train Set
£74
Hornby Extension Track Pack A
£13.70
Hornby Extension Track Pack B
£22.70
Hornby Extension Track Pack C
£22.00
Hornby Extension Track Pack D
£35.00
Hornby Extension Track Pack E
£18.60
Hornby Extension Track Pack F
£22.80
