Moderator: Raider
rmg1919 wrote:1. Are swap-meets and club fairs the best (value for money) place to buy?
Mask from the inside so one rail is entirely covered and the chairs on the
rail to be painted are exposed, mask the otherside in similar fashion. Don't
be tempted to over-adhere the masking tape - it only has to stay in place
while you paint, not survive a gale. And remove the tape as soon as you are
finished painting - I prefer to do it before the paint is dry. Spray with
red primer from halfords (don't do a thick all over... just good coverage is
enough). I then gently dust it with dark grey primer and matt black to take
the uniform look out of it - but again, don't over-do it... there should be
more rusty brown than anything else. Keep the nozel well away from what you
are painting or you'll put put a thick coat on before you know it. Once it
is dry, I go over the tops and insides of the rails with a fine file
(abrasive paper clogs too readily). The end result is very passable. Don't
forget to stain the centre of the track (i.e. half way between the rails)
with a light dusting of whatever you like - usually a subtle black streak
looks good, but I have seen white shading from chalk slurry dripping from
trains... You won't be able to do this with a spray can for N coz the spray
is to wide for delicate work like this... buy a good spray gun *** and
practice well first *** lots of air and little paint is the key! Also,
notice that in stations and regular stopping points, the entire track can be
covered with several millimeters thick of black grease and dust/dirt. this
can be simulated very effectively by filling (plaster) the ballast and
sleepers lightly in these areas to remove some of the relief - a very
runny paste smeared in with a paintbrush works well Then a spray wth satin
black... fade it on either side of that track section and again, tone down
with a dark grey, you get a nice weathered look... the rails will not be
rusty at these places... also around the blades of points will often be
black and greasy. It is a long process but persevere and just try one bit at
a time.
rmg1919 wrote: - but am not sure whether UK railways always operate as follows
LINE 1 - UP - FAST
LINE 2 - DOWN - FAST
LINE 3 - UP - SLOW
LINE 4 - DOWN - SLOW
Am I correct in thinking this is how the majority of 4-wide lines in the UK operate, or is it just the GWR that runs like this?
Return to Personal Layouts - Under Construction
Users browsing this forum: Ask Jeeves [Bot], pheasant, sprite., Yahoo [Bot] and 3 guests
