Spare room layout - as yet no name
Following on from my planning thread here http://www.newrailwaymodellers.co.uk/Fo ... 44&t=42813
Construction of the baseboards has started using 9mm ply and 69 by 18mm pse timber.
Still got a few more boards to build including the dropped level bit for the viaduct and the lift up section for the door way.
The winnie the pooh border wont come off with out ripping the wallpaper and as i am quite happy with the colour of the room (nice and light and airy) and i don't want to repaper i will cover it up with the backscene when I have decided what and how...
Appropriate signage has been obtained for the bedroom door.
http://www.jonathansnookphotography.co.uk
my layout under construction http://www.newrailwaymodellers.co.uk/Fo ... 22&t=43920
- SR/ScR Fan
Re: Spare room layout - as yet no name
Good space you've got there, and you've made a great start. Good luck!
You should definitely call it the 100 acre railway!
- luckymucklebackit
Dare you to try and blend your backscene with the very pleasant view through your window!! Best of luck with your project
A room with a view
I personally would have gone for a "No Trespassing on the Railway" sign
Regarding layout name I have been pondering on a winnie the pooh theme
spinney wood or milne wood but then they both conjure up images of lots of trees, not something I was planning on having. Other non pooh thoughts are nursery road or nursery moor.
Any suggestions are welcome.
Also after seeing the size of the main baseboard I am wondering if I have included enough track, but will wait to lay it all out before I decide as I am determined to leave space for scenery.
Nursery Road has a good ring to it.
I would say do not try to cram too much track in.
- luckymucklebackit
Milnwood Junction (albeit without the "e") is an actual place!! It is on the Motherwell to Coatbridge Line. Not sure if it is the sort of place you would want to model, a heavily industrialised area.dubbleojon wrote:Regarding layout name I have been pondering on a winnie the pooh theme
Track diagram here
http://www.signalbox.org/diagrams.php?id=661
Definitely not going down a Scottish industrial theme so best avoid that one then ....luckymucklebackit wrote:Milnwood Junction (albeit without the "e") is an actual place!! It is on the Motherwell to Coatbridge Line. Not sure if it is the sort of place you would want to model, a heavily industrialised area.dubbleojon wrote:Regarding layout name I have been pondering on a winnie the pooh theme
Track diagram here
Made a bit of progress in the last few days and this weekend, baseboard construction has finished!!
The lift out section took me ages to get right, still needs some clasps or similar to fix it in place, going to wakefield exhibition next weekend so hopefully pick something up there if not have seen some on the web.
A few pictures....
The viaduct section
The view down the main scenic board
Just the small task of varnishing them all now before starting on laying cork. Anybody ever varnished with a roller
A few pictures....
The viaduct section
- luckymucklebackit
I would think twice before varnishing, by all means varnish the legs and front of the layout but I would not attempt to varnish the top surface. When you go to glue the cork underlay down the varnish does not allow a good "key" into the wood and there is a good chance the cork will fail to stick. If you want to protect the wood give it a coat of dilute PVA before starting track laying.
How dilute would the pva need to be? I am planning on covering the whole board with cork so i can cut out for the buildings so they sink in a little bit if that makes any difference.
- luckymucklebackit
Hi - if you are covering the whole top with cork, dont bother with any preparation, just coat with a thin layer of neat PVA and apply the cork.
cheers for the advice, saved me a big job varnishing that lot.
Tons of different clasps on a well known auction site.dubbleojon wrote:The lift out section took me ages to get right, still needs some clasps or similar to fix it in place, going to wakefield exhibition next weekend so hopefully pick something up there if not have seen some on the web.
Or you could look at the ones on Station Road Baseboards site: Link
