Farish class 14
Farish class 14
Just recieved one of these in green weathered.I have got to add what a beauty of a loco and well done farish.Runs better than the 08.The only blemish is that in this days tech has no headcode lights fitted but a real gem.
richard.
richard.
D1011 western thunderer.
Fav loco class 52 Western
R.I.P Old oak common
Re: Farish class 14
where did you get it from?? i have been waiting for these to hit the shops
Re: Farish class 14
Trains4u peterborough.in stock from friday,also hattons have them in.
richard.
richard.
- Attachments
- new farish weathered class 14
- Picture 320.jpg (103.79 KiB) Viewed 3525 times
Re: Farish class 14
sweeeeet
Re: Farish class 14
Please note that the class 14 is dc only as many i have heard have been caught out on this.Other than this is a well made loco.
richard.
richard.
Re: Farish class 14
it is only DC till someone fits a chip?? i guess there is little to no space for a chip going by your post?? or do you mean it has no 6 pin socket??champion wrote:Please note that the class 14 is dc only as many i have heard have been caught out on this.Other than this is a well made loco.
richard.
Re: Farish class 14
I'm really considering owning one of these. The picture you posted has more or less made my mind up.
Is one available in BR blue weathered do you know?
Nathan.
Nathan.
"Let all men who go to don armour tomorrow remember to go before they don armour tomorrow."
Brightside Lane TMD
http://www.newrailwaymodellers.co.uk/Fo ... 22&t=33379
Brightside Lane TMD
Re: Farish class 14
Nope, but it shouldn't be difficult to DIY. The November issue of BRM has a good article about 'quick fix weathering'.Nathan20138 wrote:Is one available in BR blue weathered do you know?
G.
Re: Farish class 14
Just a basic model for dc and no 6pin socket.Looking at it inside it would be hard as with the 08 as so little space.
richard.
richard.
Re: Farish class 14
the 08 was easier than the 04 as there was much more room in the cab. in my head if the guts are similar to the heljan OO version then the only spare space will be the cab itself, and only the top half?? but i will wait and see.champion wrote:Just a basic model for dc and no 6pin socket.Looking at it inside it would be hard as with the 08 as so little space.
richard.
Re: Farish class 14
got my 14 on the way with a couple of DCC chips. hopefully i will sus the fitting of one and report back?? if i get things sussed in good time i may even send off an article to the NGS as discussed in that thread.
Re: Farish class 14
I bought myself the blue 14 today and i seem to be having problems. It seems to be a very jumpy runner unless at very high speed ( even after an hour each way) I can't work out what seems to be causing it other than the body doesn't appear to be on straight. Anyone else had this problem??
Ollie
Ollie
Re: Farish class 14
I've just got my new class 14 and it seems like Bachmann QC has taken a dive - it has big sploshes of black paint on the wheel treads, blobs of glue on the
sandboxes, missaligned brake blocks, a bowed out coupling rod and the rod retaining pin on one wheel sitting twice as proud as the others. Perhaps it's a friday afternoon jobbie. I'm almost to afraid to test run it.
G.
G.
Re: Farish class 14
don't bother, send it back for replacement and get the vendor to open the box and check it before dispatching the replacement.Grahame wrote:I've just got my new class 14 and it seems like Bachmann QC has taken a dive - it has big sploshes of black paint on the wheel treads, blobs of glue on the
G.
Re: Farish class 14
Yep, normally you'd be right about sending it back for replacement - that way the manufacturer gets to know how bad things are. However, it's easy enough to clean the paint off the wheel treads and probably sort out the coupling rods, plus the blobs of glue are underneath and will be disguised when weathered. The problem is that currently there are so many locos (3mTs, class 14s, etc) being reported as dodgy and being sent back that it is obvious that the majority of new ones are poorly finished in one way or another and the replacement is almost more likely to be worse than better. It all rather depends on how the thing runs and I won't know that until I test it later this week.locoworks wrote:don't bother, send it back for replacement and get the vendor to open the box and check it before dispatching the replacement.
G.
