OK, some pictures, as asked for.
This is all you need:
Simply wrap the copper electrical wire around the coat hanger and secure with solder (or I suppose you can use epoxy or something else):
Position the coat hanger push-rod under the baseboard. You need to drill a hole in the frame, and another under the tie bar. Push the copper wire through the hold in the tie bar. Secure in place with cable clips.
Trim the coper wire on top:
Pushing/pulling the coat hanger will operate the points.
I just need to come up with something to use as a handle on the end of the coat hanger.
Benefits - it's cheap (virtually free, in fact!); seems quite robust so far; I can operate the points without intruding onto the layout; the rods are arranged along the layout so it is easy to identify which lever operates each point; it's very cheap (did I mention that bit already?)
Disadvantages - it's a bit crude; the rods aren't together but arranged along the layout, although for me they are all within reach of the middle of the layout, & I can walk along with a hand-held controller; my layout is only 8ft long and 18" wide. It probably wouldn't be practical on a larger layout.
Comments welcome!
